Aftermarket Carb Advice.
Joey Zaciewski /
Any suggestions on an after market carburetor for my 2005 Tomos LX
-Has a Tecnigas Next exhaust if that helps at all.
The little thing gets up to a whopping 35mph on it's top end and Im looking to gain a few more mphs before going with a 70cc kit.
(edited)
Re: Aftermarket Carb Advice.
Overpriced Parts /
You should be at 40+mph. Your not jetted correctly or gear correctly please correct those two issues
Joey Zaciewski /
I have a 58 jet in the carb right now.
Stock gearing.
What number would you recommend?
low to mid 60's
The jet size that gives you proper plug chops.
Overpriced Parts /
26x24 gear
Around 60/low 60s jet
Run a head temp gauge and keep head temps 380 f or less
Google plug chop
Joey Zaciewski /
I just got a mixed package of 60's and 70's jets.
I have a 64 jet in the carb right now so next I'm looking at different sprockets.
That 26x24 gear that Ken put down, which is the 26 referring to the front or rear?
26 front, 24 rear.
1st number is always first in ratio, 26/24 or 1.083 to 1, seem high.
