Altering length of dwell section vs header - tuned pipe.
Alex Degnes /
Header length decides when the whole push/pull pulse action happens, and dwell length decides timing between the push and the pull, right?
What does a shorter/longer dwell section do for the powerband vs a shorter longer header? Other than just change the whole tuned length.
When is altering the dwell instead of the header a good idea?
This guy uses a variable dwell to tune in the pipe.
(edited)
