ZA50 Clutch
Fully adjusted clutch cable. When pulling the leaver to start engine, the leaver touches the grip/handle bar. IT slips, then grabs,when squeezing the lever really hard. Is something worn in the trans?
Re: ZA50 Clutch
Maybe, or maybe your cable or lever is not adjusted right
Re: ZA50 Clutch
Probably Fred /
Set clutch preload :
Take cabke off turn adjuster on engine until wheel drags, then turn around 5 turns out, put cable back and try it
Re: ZA50 Clutch
So.... it's an adjustment. Well.... it is... a new cable install, that I did.
Re: ZA50 Clutch
Did you check the condition of the starter clutch? I had the welds break on one side of it. Made it hard to grip.
