Re: Idle issues with kstar and SHA on Maxi
Kyle M. /
what slide are you using. there are more than 6 different ones. im guessing yours is flat on the bottom which keeps it super rich at idle. the ones with a taper are a bit more lean. what i like to do is file a small notch or two depending on what my setup wants.
like this when looking at the front of the slide... l_n_n_l or l__n__l
