kinetic pedal arms
Do any other mopeds use a 20mm pedal arm? (edited)
Re: kinetic pedal arms
Not that I am aware of mang, afaik we're stuck with the stockers, unless you go to a later model sub-frame that has the standard diameter pedal shaft higher up in it. Someone may know though.
gl
~M (edited)
Downhill Harvey (OFMC) /
With some bushings, you could use a Vespa pedal shaft.
