Re: MLM peoples pipe reviews?
Aw is puppet master pulling your string Josh hickman and getting free rent to........
LOL
I had to tap my kit for 8mm studs after the 6mm pulled out of the aluminum. I need to get long nuts as the ones I have now are so large that I must use an open ended wrench inline with the stud and turn it with a screwdriver or another tool. Even trying to get pliers or others on the nut is futile because it instantly hits the header.
Greg Salamander /
So I should get longer studs? And longer nuts? Also what jet should I try when I get the new airfilter?
Not longer studs, long nuts to put on the studs, so that the hex reaches beyond the header and can be tightened. A longer stud will just make you turn the nut more times before the wrench gets jammed against the header.
Greg Salamander /
Ok... longer nuts check
And longer bolts for where it attaches behind the kickstand?
