MLM peoples pipe reviews?
Greg Salamander /
im thinking of buying this pipe for my 2010 streeetmate r. im going to have a 26T sproket and a 60's range of jets. Do you think it is a good idea? what is the power like, and is the quality really as good as they say? thanks!
https://www.treatland.tv/MLM-tomos-A55-people-s-pipe-p/mlm-tomos-a55-pipe-377.htm
Re: MLM peoples pipe reviews?
Totally a good idea and the power is like whoa.
Greg Salamander /
what do you think the top speed will be around? and will it have good acceleration? its slightly hilly where i live
Greg Salamander /
i just ordered it
simon thokaar /
a pipe on a tomos in jersey will get you to 50mph
Greg Salamander /
Sweeet
It's the best pipe available, if you have the cash, do it
Greg Salamander /
If I put this pipe on my ped do I "need" to upjet? Will I still get a boost and will it run? Or do I need to jet.. also for a stock air filter stock everything. Will I need to drill holes in the stock intake? And what jet size should I start with?
It's time you start learning how to use the wiki and do a search.
Spoon feeding will only teach you the shape of a spoon.
Greg Salamander /
But it's alot easier!
Greg Salamander /
That was a stupid response but seriously in the time it took you to write that you probably could have answered the question in like 3 words
I know and you don't, so ha ha.
You NJ kids are lazy fucks.
Greg Salamander /
that we are! so bottom line 60's jets a 26 tooth sproket and an mlm people pipe would you say 45mph? or 40?
I would say your answers are but a short search away
Rob GasketFace /
Jets aren't mods that you swap out to go faster. You need to find the right jet size for your set up. Being off by a few sizes will make your bike run like shit. A few more sizes and you can fuck up your engine.
You can't learn mopeds by asking questions. Start here:
http://www.mopedarmy.com/wiki/Fred%27s_Guide
stop being a cock to this kid. jesus fucking christ.
mlm pipes are the best money can buy, their performance on a stock cylinder is akin to a biturbo honestly, it is with a kit that these pipes REALLY shine. to see the WHOA power they are capable of you will need to pair them with a kit. to see nice moderate gains on a stock set up, expect to see mid 30s with what you have and that upjet (yes you HAVE to). upgrade that carb to 15mm for high 30s. taller gearing will see low 40s. throw a kit on top of that to see anywhere from low 50s to low 60s.
again, this is all about how you tune your bike, but with that pipe, a carb upgrade, and taller gearing should be plenty power for everyday riding.
next time someone gives you shit for asking a simple question tell em to suck your dick.
Josh why don't you just spoon feed all the Nubbs, BS info so thy Smear.
Then you can have them send you money and never send them the parts thy pad for, LOL.
Just read the Josh Hickman links.
https://www.mopedarmy.com/forums/read.php?1,3660056,page=1
https://www.mopedarmy.com/forums/read.php?1,599407,599407#msg-599407
https://www.mopedarmy.com/forums/read.php?1,755946,755946#msg-755946
Well when he pays his tickets to get the boot off the moped rescue truck.
https://www.mopedarmy.com/forums/read.php?1,610199,610199#msg-610199
Cud driving/blowing red lights be part of the boot problem.
https://www.mopedarmy.com/forums/read.php?1,576312,576312#msg-576312
And the Dope growing did not pan out ether.
https://www.mopedarmy.com/forums/read.php?1,606387,606387#msg-606387
More BS.
https://www.mopedarmy.com/forums/read.php?1,786989,page=1
And this ones the best he fucks over so many Moped riders in this thread thy made him a LOGO member, LOL
https://www.mopedarmy.com/forums/read.php?1,930441,page=1
Hey wayne, use your magikal wizard powers to fix the search. Either that or add Hashtagging to MA's forums, and bring it up to 2006 snuff.
That's why i have all those links and info in my profile for the window lick'rs.
This NJ nubb has 3 threads going on the same pipe shit, hes just a NJ spoon feed me punk.
Bet his Mommy can do a search just fine and feed him she found him in a park you know.
P.S.
The search works just fine if you enter the right info (edited)
I really don't like New Jersey.
Greg Salamander /
They say it is a "perfect fit" when in fact it was a bitch to get on and isn't even on correctly now....
You'll need to use tall nuts like the kind treats has. The header is super wide so getting the old nuts on there can be a bitch.
Or go pro and use allen bolts instead of studs.
Have to admit, its gonna be hard to defend you if you can't put a pipe on
Greg Salamander /
Ik still a newbie, but we all have to start somewhere. I just redid my entire top end so I'm getting to know my way around the ped.. I think I'm going to use Allen bolts! That's a great idea! And also I'll try the longer bolts.
BTW, I'm using a 62 jet and a 28 rear sproket. I'm not getting the acceleration I need! Any tips/ suggestions.
I'm getting a K&N deltorro phva carb air filter. .. what jet should I try first? Also I'm getting a 24 tooth sproket... do you think I can break 40? My moped idles weird cause the throttle cable is too long.. needs to taka a good 15 mins to warm up...
Sorry for so many questions just want to get it running the best it can!
If the cable is too long it will have ZERO effect on your idle. Too short, maybe.
Greg Salamander /
Idk what to do then... if I Rev it the slightest bit it idles fine for like 30 seconds then it just slowly shuts off. So I rigged the line a bit to pull the cable? Idk what else to try. I'm thinking a new carb all together. Perferably a new 17.5 mm any suggestions for that?
Unplug your pilot jet id equipped. Adjust idle air screw if equipped.. hell, turn you idle speed up!
Studs and long brass 9mm head nuts for the win.
Allen bolts will work loose, strip out, or cross thread your cylinder treads.
Do it right don't be a pro retard.
Sounds like you need to turn up the idle and assess jetting from there.
Wayne advice is sketchy at best. https://www.mopedarmy.com/forums/read.php?7,3108964
Listen to the people who live the moped lifestyle. They will steer you right.
Keep it up man! You're almost there!
I'm the puppet master pulling your string Josh and getting free rent LOL
Josh Hickman is the biggest scum bag on the MA forms.....
I like how you cried to Simon like a bleeding bitch and had him lock the thread you got called out in for fucking most of the MA users over in.
And this is the thread in quston he fucks over so many Moped riders thy made him a LOGO member, LOL
And your turd list is so long on the MA forms.
Just read some of the links.
More BS.
Now he has a moped shop of mayham LOL.
Hes kissing 1977 mopeds ass in this thread.
BAN Josh Hickman.
C.W.
ugh. it really sucks that you have to deal with a guy who takes pills for his brain damage and cant figure out how to screw in a bolt. ignore him if you can. we do.
anyways...
allen bolts are totally the way to go, especially for a peoples pipe. you can try the long nuts too but they are still a tight fit for a socket, and depending on your cylinder, it can also be tight for a plain old wrench. we install mlm pipes on every custom build we do at the shop, seeing as mlm is a block away. you can take my word for it, or the guy who called you an idiot.
keep at it, tomos are super easy to make go fast, but i think from here if you have a jetting question, a new thread may be best as this ones got shit all over it lol.
do it brother!
