Re: Modifications for crazy low end power on my H2O NC50
Derrick Oyervides /
I can go ahead and tell you from the start a 70 jet is way to small if it's a 70 cc. Friend of mine had a 92 jet on his express with a 12mm carb and sift seized it numerous times before I had the wide and to dial it in. With a 15mm carb I would say at least a 90 to 100 jet. His wasn't water cooled and didn't have a temp sensor either but I guarantee his was about 450 degrees. Even if it's water cooled it can still be damaged by running to lean even if it's at 200 degrees. Cars thermostats open at around 165-185 degrees. "Most Hondas I've worked on" and peak temp around 220 before the ecu "hondata s300" runs in limp mode with a check engine light. Up your main jet and do some plug chops and you should be fine. My friends express was a 1 speed so it revved really high at 40 mph.
  Modifications for crazy low end power on my H2O NC50Topic by: Rob GasketFace Rob GasketFace 07/15/14 11:55PM
  Re: Modifications for crazy low end power on my H2O NC50Re: Rob GasketFace Rob GasketFace 07/16/14 12:03AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Ryan . Ryan . 07/16/14 07:33AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Derrick Oyervides Derrick Oyervides 07/16/14 08:16AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Ryan . Ryan . 07/16/14 08:50AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Derrick Oyervides Derrick Oyervides 07/16/14 09:32AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Eric Jaromin Eric Jaromin 07/16/14 08:53AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Moby Express Moby Express 07/16/14 09:35AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Derek Stahl Derek Stahl 07/16/14 09:51AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Ryan . Ryan . 07/16/14 10:14AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Ryan . Ryan . 07/20/14 12:04AM
  Re: Modifications for crazy low end power on my H2O NC50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/20/14 05:05AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Rob GasketFace Rob GasketFace 07/16/14 10:19AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Declan g Declan g 07/20/14 12:30AM
  Re: Modifications for crazy low end power on my H2O NC50Re: simon zarka simon zarka 07/20/14 02:08AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Vincent Becker Vincent Becker 03/22/15 08:35PM
  Re: Modifications for crazy low end power on my H2O NC50Re: Rob GasketFace Rob GasketFace 03/22/15 09:41PM
  Re: Modifications for crazy low end power on my H2O NC50Re: Princess Rapunzel Princess Rapunzel 03/23/15 01:06AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Maciek Dub Maciek Dub 03/23/15 11:26AM
  Re: Modifications for crazy low end power on my H2O NC50Re: will warn will warn 03/23/15 07:15PM
  Re: Modifications for crazy low end power on my H2O NC50Re: Cameron Acuff Cameron Acuff 03/23/15 08:46PM
  Re: Modifications for crazy low end power on my H2O NC50Re: Ryan . Ryan . 03/23/15 08:57PM
  Re: Modifications for crazy low end power on my H2O NC50Re: Cameron Acuff Cameron Acuff 03/23/15 09:22PM
  Re: Modifications for crazy low end power on my H2O NC50Re: Chris . Chris . 03/23/15 09:34PM
  Re: Modifications for crazy low end power on my H2O NC50Re: Ryan . Ryan . 03/23/15 11:03PM
  Re: Modifications for crazy low end power on my H2O NC50Re: Steve Vitale Steve Vitale 03/24/15 03:42PM
  Re: Modifications for crazy low end power on my H2O NC50Re: «tyler » «tyler » 03/25/15 12:33AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Rob GasketFace Rob GasketFace 03/25/15 08:42AM
  Re: Modifications for crazy low end power on my H2O NC50Re: Steve Vitale Steve Vitale 03/25/15 04:53PM
  Re: Modifications for crazy low end power on my H2O NC50Re: Ryan . Ryan . 03/25/15 11:17PM
