Satanic Base Gasket
I'm that guy that keeps complaining about the excessive carb blowback. So my case is matched to a 70cc K-Star but the gaskets aren't. You know how alot of aftermarket cylinders come with a non matching base gasket ( Which makes me mad and confused). When the ports are open while the piston is at the bottom of the stroke, the gas mixture travels from the crankcase to the transfer ports and so forth. Well while its traveling can the excessive base gaskets material in the case make so the mixture is pushed back or restricted? I hope someone understands what Im trying to say. Thank You
Re: Satanic Base Gasket
Just use a razor while it's on the cylinder studs to match them. Yes, it'll will be restrictive and defeat the point of case matching.
I was hoping to see case matching in the likeness of an inverted cross or pentagram.
Salsa Valentina /
Okay, I see now. Thank You
Probably Fred /
You mean you didn't match/dremel your engine cases to the kit/cylinder too.
So your blaming Satin for your stupidity, hows that working for you?
Salsa Valentina /
I did except for the base gasket that I'm currently using
> currently using
Hows that working for you?
Dirty30 Dillon /
You went through the trouble of cutting the aluminum walls of the engine transfers...
But didn't use an X-acto knife to cut a paper gasket?
Probably Fred /
> gasket?
Then how did he transfer the transfer ports size from the cylinder to the case without matching the gasket to the cylinder first then the gasket to case .
My guess he did none of it that's why the gas blew back into his carburetor.
Probably didn't base space either.
Nothing a good old exorcism couldn't take care of....
Salsa Valentina /
Used a very old base gasket for the transfers then threw that out and used a new one
