78' Honda Express Nc50 Rim Swap
Does anyone know of any alternative rims for an express?
Re: 78' Honda Express Nc50 Rim Swap
I've been searching, and all I've found is "NO".
other express wheels mostly, at least for the back.
NH80 rear wheel may fit as well, if it wont hit the case, and if the rear brake fits in the drum.
You cant fit anything bigger than a 14 out back anyway unless you have a variator case. then i believe you can go up to 16".
Front is easy, like any other ped. youll need to swap forks if you want anything bigger than a 14 though. (edited)
a hobbit or urban express front end will bolt right on, urban has the biggest brakes if that matters to you.
