Finally here!!
Finally from 1977!!
Re: Finally here!!
wow you ordered that shit in 1977 and it just arrived?
Re: Finally here!!
Dirty30 Dillon /
Why is your pipe so crusty... I hope that is the WSL and not a Proma...
Re: Finally here!!
matt boda1nz /
Pipe looks used/returned.
Re: Finally here!!
If that's the k star stocko shocko 44 mm kit I suggest you look at it pretty carefully. Quality is sketch. Check to make sure the transfers are open at bdc and you will need to deck the top to get a decent squish and mine wasn't square. Go get a dr and bolt it on instead. Upjet that baby to at least an 88 main and break it in with a temp,gauge. I finally got mine right on the third piston.
Re: Finally here!!
pretty sure its a DR, what with the DR box sitting next to it and all...
good setup, 50 mph wheelie power, lots of fun. all those pipes look like turds brand new, citri-strip for 3 hours will soften that crappy clear coat paint and it comes off really easy with an angle grinder wire brush, then you can PAINT IT BLACK!! or neon purple or whatever color you want it to be. or just leave it ugly, hobbits run better ugly.
don't spend 6 hours trying to sandblast it like marc did... that's doing it the "hard way".
Re: Finally here!!
Alex Nelson /
yup its a DR kit but its for an NU50 not a hobbit. I just need to move the brackets on the pipe around to get it to fit and ill be ready to rip!
Re: Finally here!!
Dirty30 Dillon /
Gospel.
