Re: Ring gap over port, port width.
Alex Degnes /
The ring gap is running between the secondaries and boost port, if I cut two additional boost ports, it would run straight over one of them. This should not be a problem, I've seen many cylinders where the gap is running across bigger ports than that. But, widening the existing ports should give more power, if propperly aimed, because of bigger area without the extra "port dividers" 5 transfers vs 7 transfers. Without moving the pin, the gap would slide off center over one off the widened secondaries, this may or may not be a problem...
  Ring gap over port, port width.Topic by: Alex Degnes Alex Degnes 07/01/14 03:02AM
  Re: Ring gap over port, port width.Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/01/14 03:17AM
  Re: Ring gap over port, port width.Re: Graham Motzing Graham Motzing 07/01/14 10:03AM
  Re: Ring gap over port, port width.Re: Flagrant - Flagrant - 07/01/14 11:46AM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/01/14 05:35PM
  Re: Ring gap over port, port width.Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/01/14 05:49PM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/02/14 03:48AM
  Re: Ring gap over port, port width.Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/02/14 06:07AM
  Re: Ring gap over port, port width.Re: JBOT Admin JBOT Admin 07/01/14 11:44AM
  Re: Ring gap over port, port width.Re: Flagrant - Flagrant - 07/01/14 11:48AM
  Re: Ring gap over port, port width.Re: Graham Motzing Graham Motzing 07/01/14 12:07PM
  Re: Ring gap over port, port width.Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/01/14 12:03PM
  Re: Ring gap over port, port width.Re: JBOT Admin JBOT Admin 07/01/14 12:29PM
  Re: Ring gap over port, port width.Re: Graham Motzing Graham Motzing 07/01/14 01:47PM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/01/14 03:16PM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/01/14 03:06PM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/01/14 03:37PM
  Re: Ring gap over port, port width.Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/01/14 05:18PM
  Re: Ring gap over port, port width.Re: JBOT Admin JBOT Admin 07/01/14 04:35PM
  Re: Ring gap over port, port width.Re: Blake MD No PM Plz Blake MD No PM Plz 07/01/14 04:41PM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/02/14 03:52AM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/02/14 07:32AM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/02/14 07:33AM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/02/14 07:40AM
  Re: Ring gap over port, port width.Re: Graham Motzing Graham Motzing 07/02/14 09:33AM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/07/14 01:09PM
