Ring gap over port, port width.
Alex Degnes /
How wide, relative to bore, can you make a port, and still run the ring gap over it without snagging?
Any rule of thumb, or anyone with good/bad experience?
I want more port time area, cutting two small ports between the secondaries and the boost port is an option, but that would not give as much area as just widening the existing ports.
Moving ring pin to run in the middle of the boost port is an option, or get a piston with the pin located in the right place.
  Ring gap over port, port width.Topic by: Alex Degnes Alex Degnes 07/01/14 03:02AM
  Re: Ring gap over port, port width.Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/01/14 03:17AM
  Re: Ring gap over port, port width.Re: Graham Motzing Graham Motzing 07/01/14 10:03AM
  Re: Ring gap over port, port width.Re: Flagrant - Flagrant - 07/01/14 11:46AM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/01/14 05:35PM
  Re: Ring gap over port, port width.Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/01/14 05:49PM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/02/14 03:48AM
  Re: Ring gap over port, port width.Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/02/14 06:07AM
  Re: Ring gap over port, port width.Re: JBOT Admin JBOT Admin 07/01/14 11:44AM
  Re: Ring gap over port, port width.Re: Flagrant - Flagrant - 07/01/14 11:48AM
  Re: Ring gap over port, port width.Re: Graham Motzing Graham Motzing 07/01/14 12:07PM
  Re: Ring gap over port, port width.Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/01/14 12:03PM
  Re: Ring gap over port, port width.Re: JBOT Admin JBOT Admin 07/01/14 12:29PM
  Re: Ring gap over port, port width.Re: Graham Motzing Graham Motzing 07/01/14 01:47PM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/01/14 03:16PM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/01/14 03:06PM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/01/14 03:37PM
  Re: Ring gap over port, port width.Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/01/14 05:18PM
  Re: Ring gap over port, port width.Re: JBOT Admin JBOT Admin 07/01/14 04:35PM
  Re: Ring gap over port, port width.Re: Blake MD No PM Plz Blake MD No PM Plz 07/01/14 04:41PM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/02/14 03:52AM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/02/14 07:32AM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/02/14 07:33AM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/02/14 07:40AM
  Re: Ring gap over port, port width.Re: Graham Motzing Graham Motzing 07/02/14 09:33AM
  Re: Ring gap over port, port width.Re: Alex Degnes Alex Degnes 07/07/14 01:09PM
