Moby- Air Leak at head nut/stud
OK... anyone else deal with this before?
I was examining the head and noticed oil on the head.... I thought it could have been the spark plug seeping oil so I cleaned the area up and fired the engine back up.
I noticed between the nut and stud that there was small bubbles forming hence the air leak.
any ideas how this can happen?
the nut was a bit smaller than the stock nuts and I placed a split lock washer under the nut. I have replaced it with a different washer and the stock nut... fired it up and no evidence of bubbling oil but am i hiding another problem?
thanks
Re: Moby- Air Leak at head nut/stud
rick ziereis /
sounds like it's seeping past the head gasket and into the stud space. Tighten/ check torque on the head, or replace the head gasket.
will check it.... its a bidalot head with o-ring so I was almost thinking that it could be leaking from the base gasket and filling up the cyl stud channel then eventually leaking out the head stud/nut area.
WFFF
Matt Zimmerman /
If its an o ringed head than pretty safe bet that the leak is from the gasket at the cylinder base. I have had that before. Its generally frowned upon but I use a small amount of sealant on both sides of the gasket if I have a persistant leak. I than vacuum/pressure test the motor to ensure its leak free. Good luck
