Re: Intake manifold
Larry Charrlin /
Thanks...guess I should have been clearer, also using a 15.5 Dellorto and there is NO room on the Silver bullet to fit under the tank. Forget the side cover...that's a lost cause. So far have cut the intake in half and lengthened it a bit....with rubber connector for flexibility....now fits up against the engine case with about 2mm of clearance for the pedals.... have to wait and see how that works out. .....removed two fins on cylinder to clear the petcock...fuel line with filter is about 3 inches long !!!. I know this Airsal kit wasn't made for the Bullet...but damn...it sure would have been nice if the intake had just been made to be reversible to use on either side...A3 engine is offset to the left on Bullet so there plenty of clearance on left side
