JAWA with Walbro carb
Just thought some of you may find this interesting.My 93 Jawa210 ,all stock with a 16mm Walbro HDC carb fron a Homelite chain saw. A Tecumseh airfilter and the adapter made from gray plastic conduit
Went on a 63 mile ride Sunday in the state forest roads of Pa. and it never missed a beat. Adjustable High and low fuel mixture needles that once set were never touched again. Cruised at 30-37 mph depending on the road surface. The carb works flawlessly at all throttle settings and has nice and smooth acceleration..
Re: JAWA with Walbro carb
Andrew Squiggman /
cool use of the carb. that air filter is gonna hate puddles and rain though
Vlado vlado /
nice job!
Duane Trout /
Thanks, works well and was inexpensive-junk saws are everywhere..
this thread has exceeded expectations!
excellent work. is 35+ a GPS speed or from the stock speedo?
Nice! I love off beat carbs!
Charlie BUZZARD Wrote:
> Nice! I love to beat off carbs!
gross dude.
Probably Fred /
> do they spit gas when your done?
> gross dude.
> gross dude.
I don't see the ejaculate pump line coming from the carter, so you must be sucking past the pump.
Road Rash Dave /
Agreed Wayne
It would work better with a line running from the carter/case to the ejaculate pump IE diaphragm pump its the small hole below the throttle bore...it should go to the case as it does in the chain saw or weed wacker that it came from
Wherever you can get the most sucktion I guess but really how much suction does it need its just squirting into a Jawa
Also this sucker doesn't have to pull because of head pressure but just has to push
Duane Trout /
from the stock speedo but I was riding with a freind who has a new 250 Kawasaki dual sport and he quoted the same..
Duane Trout /
No - does not spit gas at all No leakage and works fine!
Duane Trout /
Yes doesn't need to pull have gravity for supply..
Were just road 50 miles on Sunday Again with no problems.. cruising 35 mph. Im working with exhaust tips on the stock pipe now. added a cut off Brakleen can (top half ) with no baffles in pipe and a 1/2 " hole where the spray nozzle was. What a improvement in mid range power...
Duane Trout /
Thanks Graham
Sweet, I am going to try this on a 210 sport I just picked up.
dope. sweet jawa
*Radium City* Barney /
Nice. I used an old Bing I had laying around. Just had to make a round spacer and weld it to the stock Jawa intake. Worked great.
Cool, I like the 80s stickers on the old frame! (edited)
