Re: temp gauge
Emil Kniemel /
Graham Motzing Wrote:
> Ken Roff Wrote:
> > The plug crush washer acts like a insulator.
> You
> > need both sides of the sensor covered with same
> > hot temperature( plug and head) nothin between.
> > Again per trail tech: remove crush washer
> people
> Insulating between what and what? High temp and
> High temp?
> The threads conduct heat the same
> the bottom surface of the spark plug conducts heat
> from the plug, into the head through the crush
> washer
> the copper terminal conducts heat the same whether
> it has a washer against it or not
> the head conducts heat the same into the copper.
> the copper seals to the head
> the washer seals to the head
> the washer seals to the copper
> its exactly the same, i'm just fucking lazy and
> snce i'm going to take the thing off after 2 or 3
> test runs, and i want to use my same spark plug, i
> don't bother taking the washer off. I also re-use
> crush gaskets. holy shit tell the tuning police
> that i'm 'doing it wrong'
> you seized at less than 400 degrees because you
> don't know how to tune. CHT tells you the temp of
> your cylinder head, you seize because your piston
> gets too hot and expands in the bore, the two
> temperatures are only circumstantially similar.
> Up until last summer i never seized anything ever.
> I've built dozens and dozens of engines, all sorts
> of different wacky shit and up until 2 years ago
> never even ran a CHT...
> people tuned 2 stroke engines for 70 years before
> anyone ever heard of a trail tech. CHT is a stupid
> tool that tells you useless garbage stupid data
> and everyone thinks it came out of Jesus' vag or
> something.
i aint gonna argue with that! switching from stock hobbit carb to vm18 i switched out my plug too and relied on the CHT rather than the ol' "plug chop".
  temp gaugeTopic by: matt madden matt madden 06/03/14 12:41PM
  Re: temp gaugeRe: Ben Whittle Ben Whittle 06/03/14 12:55PM
  Re: temp gaugeRe: Flagrant - Flagrant - 06/03/14 06:41PM
  Re: temp gaugeRe: Graham Motzing Graham Motzing 06/03/14 12:59PM
  Re: temp gaugeRe: Derek Vanasse Derek Vanasse 06/03/14 01:36PM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/03/14 01:37PM
  Re: temp gaugeRe: Graham Motzing Graham Motzing 06/03/14 01:58PM
  Re: temp gaugeRe: matt madden matt madden 06/03/14 02:08PM
  Re: temp gaugeRe: moby mcfly moby mcfly 06/03/14 02:17PM
  Re: temp gaugeRe: matt boda1nz matt boda1nz 06/03/14 03:12PM
  Re: temp gaugeRe: matt madden matt madden 06/03/14 03:14PM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/03/14 03:40PM
  Re: temp gaugeRe: matt madden matt madden 06/03/14 03:54PM
  Re: temp gaugeRe: Ryan Martian Ryan Martian 06/03/14 04:23PM
  Re: temp gaugeRe: Time Warner Time Warner 06/03/14 06:10PM
  Re: temp gaugeRe: Emil Kniemel Emil Kniemel 06/03/14 08:40PM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/03/14 10:11PM
  Re: temp gaugeRe: Graham Motzing Graham Motzing 06/04/14 11:58AM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 12:09PM
  Re: temp gaugeRe: Emil Kniemel Emil Kniemel 06/04/14 12:29PM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 12:33PM
  Re: temp gaugeRe: matt madden matt madden 06/04/14 12:45PM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 09:34AM
  Re: temp gaugeRe: matt madden matt madden 06/04/14 09:50AM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/04/14 09:51AM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 09:57AM
  Re: temp gaugeRe: matt madden matt madden 06/04/14 10:25AM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 10:59AM
  Re: temp gaugeRe: matt madden matt madden 06/04/14 11:04AM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/04/14 12:26PM
  Re: temp gaugeRe: Ryan Martian Ryan Martian 06/04/14 01:30PM
  Re: temp gaugeRe: Graham Motzing Graham Motzing 06/04/14 02:17PM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 06:22PM
  Re: temp gaugeRe: Ryan Martian Ryan Martian 06/04/14 06:59PM
  Re: temp gaugeRe: Maciek Dub Maciek Dub 06/04/14 07:02PM
  Re: temp gaugeRe: Marc Friedman Marc Friedman 06/04/14 07:06PM
  Re: temp gaugeRe: T y l e r T y l e r 06/04/14 07:08PM
  Re: temp gaugeRe: Marc Friedman Marc Friedman 06/04/14 07:37PM
  Re: temp gaugeRe: T y l e r T y l e r 06/05/14 12:48AM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/05/14 12:03PM
  Re: temp gaugeRe: Maciek Dub Maciek Dub 06/05/14 07:32PM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/06/14 09:34AM
  Re: temp gaugeRe: matt boda1nz matt boda1nz 06/05/14 10:12PM
  Re: temp gaugeRe: Marc Friedman Marc Friedman 06/05/14 10:36PM
  Re: temp gaugeRe: matt boda1nz matt boda1nz 06/05/14 10:43PM
  Re: temp gaugeRe: Brent Bublitz Brent Bublitz 06/06/14 02:51PM
  Re: temp gaugeRe: scott middleton scott middleton 06/06/14 03:29PM
  Re: temp gaugeRe: Ryan Mc Ryan Mc 06/06/14 03:30PM
