Re: temp gauge
Graham Motzing /
Ken Roff Wrote:
> The plug crush washer acts like a insulator. You
> need both sides of the sensor covered with same
> hot temperature( plug and head) nothin between.
> Again per trail tech: remove crush washer people
Insulating between what and what? High temp and High temp?
The threads conduct heat the same
the bottom surface of the spark plug conducts heat from the plug, into the head through the crush washer
the copper terminal conducts heat the same whether it has a washer against it or not
the head conducts heat the same into the copper.
the copper seals to the head
the washer seals to the head
the washer seals to the copper
its exactly the same, i'm just fucking lazy and snce i'm going to take the thing off after 2 or 3 test runs, and i want to use my same spark plug, i don't bother taking the washer off. I also re-use crush gaskets. holy shit tell the tuning police that i'm 'doing it wrong'
you seized at less than 400 degrees because you don't know how to tune. CHT tells you the temp of your cylinder head, you seize because your piston gets too hot and expands in the bore, the two temperatures are only circumstantially similar.
Up until last summer i never seized anything ever. I've built dozens and dozens of engines, all sorts of different wacky shit and up until 2 years ago never even ran a CHT...
people tuned 2 stroke engines for 70 years before anyone ever heard of a trail tech. CHT is a stupid tool that tells you useless garbage stupid data and everyone thinks it came out of Jesus' vag or something.
  temp gaugeTopic by: matt madden matt madden 06/03/14 12:41PM
  Re: temp gaugeRe: Ben Whittle Ben Whittle 06/03/14 12:55PM
  Re: temp gaugeRe: Flagrant - Flagrant - 06/03/14 06:41PM
  Re: temp gaugeRe: Graham Motzing Graham Motzing 06/03/14 12:59PM
  Re: temp gaugeRe: Derek Vanasse Derek Vanasse 06/03/14 01:36PM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/03/14 01:37PM
  Re: temp gaugeRe: Graham Motzing Graham Motzing 06/03/14 01:58PM
  Re: temp gaugeRe: matt madden matt madden 06/03/14 02:08PM
  Re: temp gaugeRe: moby mcfly moby mcfly 06/03/14 02:17PM
  Re: temp gaugeRe: matt boda1nz matt boda1nz 06/03/14 03:12PM
  Re: temp gaugeRe: matt madden matt madden 06/03/14 03:14PM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/03/14 03:40PM
  Re: temp gaugeRe: matt madden matt madden 06/03/14 03:54PM
  Re: temp gaugeRe: Ryan Martian Ryan Martian 06/03/14 04:23PM
  Re: temp gaugeRe: Time Warner Time Warner 06/03/14 06:10PM
  Re: temp gaugeRe: Emil Kniemel Emil Kniemel 06/03/14 08:40PM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/03/14 10:11PM
  Re: temp gaugeRe: Graham Motzing Graham Motzing 06/04/14 11:58AM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 12:09PM
  Re: temp gaugeRe: Emil Kniemel Emil Kniemel 06/04/14 12:29PM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 12:33PM
  Re: temp gaugeRe: matt madden matt madden 06/04/14 12:45PM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 09:34AM
  Re: temp gaugeRe: matt madden matt madden 06/04/14 09:50AM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/04/14 09:51AM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 09:57AM
  Re: temp gaugeRe: matt madden matt madden 06/04/14 10:25AM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 10:59AM
  Re: temp gaugeRe: matt madden matt madden 06/04/14 11:04AM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/04/14 12:26PM
  Re: temp gaugeRe: Ryan Martian Ryan Martian 06/04/14 01:30PM
  Re: temp gaugeRe: Graham Motzing Graham Motzing 06/04/14 02:17PM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 06:22PM
  Re: temp gaugeRe: Ryan Martian Ryan Martian 06/04/14 06:59PM
  Re: temp gaugeRe: Maciek Dub Maciek Dub 06/04/14 07:02PM
  Re: temp gaugeRe: Marc Friedman Marc Friedman 06/04/14 07:06PM
  Re: temp gaugeRe: T y l e r T y l e r 06/04/14 07:08PM
  Re: temp gaugeRe: Marc Friedman Marc Friedman 06/04/14 07:37PM
  Re: temp gaugeRe: T y l e r T y l e r 06/05/14 12:48AM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/05/14 12:03PM
  Re: temp gaugeRe: Maciek Dub Maciek Dub 06/05/14 07:32PM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/06/14 09:34AM
  Re: temp gaugeRe: matt boda1nz matt boda1nz 06/05/14 10:12PM
  Re: temp gaugeRe: Marc Friedman Marc Friedman 06/05/14 10:36PM
  Re: temp gaugeRe: matt boda1nz matt boda1nz 06/05/14 10:43PM
  Re: temp gaugeRe: Brent Bublitz Brent Bublitz 06/06/14 02:51PM
  Re: temp gaugeRe: scott middleton scott middleton 06/06/14 03:29PM
  Re: temp gaugeRe: Ryan Mc Ryan Mc 06/06/14 03:30PM
