Re: temp gauge
Deadped Ryan /
Lol... I just cram the meter into my cables... It's an el-cheapo automotive multimeter and I use it for tons of stuff. I'm with graham and only like to use temp sensors during setup, not once I have a setup tuned. Usually I'll just feel the fin with my finger while I'm going up monster hills or over-revving and I can tell if it's getting close to too hot or way too hot. I've almost had accidents looking at temp sensors before in traffic and by reaching down to feel it I don't have to look away from the road.
I've cut down on the metal mass from the picture above (removed the bolt from the thermocouple and decreased the amount of solder in the terminal crimp end), but even with the reduced mass, it's still more thermal mass to heat than a trailtech. You'll know if you're in the too hot ballpark though and that's all I wanted. The sensor was within 2 degrees of what I expected in the oven and boiling water, so I feel like worst case scenario with the increased mass it's 10*F low. I'll have to compare to someone with a trailtech at a rally. It'll for sure tell you if you're in the ball park - and that's all you really need.
It's just a large copper electrical terminal + plumbing solder + amazon thermocouple.
I've used it to play around with how much timing I can get away with on my derbi and as a verification of temps on my vespa.
You can pickup type K readers super cheap though if you don't want to buy a multimeter
Completely repairable, re-usable, more widespread and available. You end up with more function for your money too IMO. You can weld up bungs with compression fittings and use them for EGT too. (edited)
  temp gaugeTopic by: matt madden matt madden 06/03/14 12:41PM
  Re: temp gaugeRe: Ben Whittle Ben Whittle 06/03/14 12:55PM
  Re: temp gaugeRe: Flagrant - Flagrant - 06/03/14 06:41PM
  Re: temp gaugeRe: Graham Motzing Graham Motzing 06/03/14 12:59PM
  Re: temp gaugeRe: Derek Vanasse Derek Vanasse 06/03/14 01:36PM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/03/14 01:37PM
  Re: temp gaugeRe: Graham Motzing Graham Motzing 06/03/14 01:58PM
  Re: temp gaugeRe: matt madden matt madden 06/03/14 02:08PM
  Re: temp gaugeRe: moby mcfly moby mcfly 06/03/14 02:17PM
  Re: temp gaugeRe: matt boda1nz matt boda1nz 06/03/14 03:12PM
  Re: temp gaugeRe: matt madden matt madden 06/03/14 03:14PM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/03/14 03:40PM
  Re: temp gaugeRe: matt madden matt madden 06/03/14 03:54PM
  Re: temp gaugeRe: Ryan Martian Ryan Martian 06/03/14 04:23PM
  Re: temp gaugeRe: Time Warner Time Warner 06/03/14 06:10PM
  Re: temp gaugeRe: Emil Kniemel Emil Kniemel 06/03/14 08:40PM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/03/14 10:11PM
  Re: temp gaugeRe: Graham Motzing Graham Motzing 06/04/14 11:58AM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 12:09PM
  Re: temp gaugeRe: Emil Kniemel Emil Kniemel 06/04/14 12:29PM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 12:33PM
  Re: temp gaugeRe: matt madden matt madden 06/04/14 12:45PM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 09:34AM
  Re: temp gaugeRe: matt madden matt madden 06/04/14 09:50AM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/04/14 09:51AM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 09:57AM
  Re: temp gaugeRe: matt madden matt madden 06/04/14 10:25AM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 10:59AM
  Re: temp gaugeRe: matt madden matt madden 06/04/14 11:04AM
  Re: temp gaugeRe: Overpriced Parts Overpriced Parts 06/04/14 12:26PM
  Re: temp gaugeRe: Ryan Martian Ryan Martian 06/04/14 01:30PM
  Re: temp gaugeRe: Graham Motzing Graham Motzing 06/04/14 02:17PM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/04/14 06:22PM
  Re: temp gaugeRe: Ryan Martian Ryan Martian 06/04/14 06:59PM
  Re: temp gaugeRe: Maciek Dub Maciek Dub 06/04/14 07:02PM
  Re: temp gaugeRe: Marc Friedman Marc Friedman 06/04/14 07:06PM
  Re: temp gaugeRe: T y l e r T y l e r 06/04/14 07:08PM
  Re: temp gaugeRe: Marc Friedman Marc Friedman 06/04/14 07:37PM
  Re: temp gaugeRe: T y l e r T y l e r 06/05/14 12:48AM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/05/14 12:03PM
  Re: temp gaugeRe: Maciek Dub Maciek Dub 06/05/14 07:32PM
  Re: temp gaugeRe: Deadped Ryan Deadped Ryan 06/06/14 09:34AM
  Re: temp gaugeRe: matt boda1nz matt boda1nz 06/05/14 10:12PM
  Re: temp gaugeRe: Marc Friedman Marc Friedman 06/05/14 10:36PM
  Re: temp gaugeRe: matt boda1nz matt boda1nz 06/05/14 10:43PM
  Re: temp gaugeRe: Brent Bublitz Brent Bublitz 06/06/14 02:51PM
  Re: temp gaugeRe: scott middleton scott middleton 06/06/14 03:29PM
  Re: temp gaugeRe: Ryan Mc Ryan Mc 06/06/14 03:30PM
