14 mm intake on 12 mm carb
When i was looking through some moped parts and found a 14 mm intake, i have a 12 mm bing on a mostly standard e50, will putting the 14mm intake on it do anything performancewise or should i not bother
Re: 14 mm intake on 12 mm carb
Bas Autowas /
Just got off the phone with a friend who studied moped repairs and he says it doenst do anything so thats solved
hmm, it might. especially if its a 'square' port and you are putting it on an aluminum plated cylinder.
shouldn't take more than 10 or 15 minutes, give it a go!
Probably Fred /
Yes it helps most puch 2HP came with 14 MM intake with a 12 MM Bing carburetor. Ya it helps a tad
its just mopeds, TRY IT!
Bas Autowas /
The outer side of the intake is smaller than the 12 mm one so the carb fits too loosely, so no 14mm intakes for now
make a shim if anything it might help things flow better
