Jetting for this set up?
John Carlile /
About to order some jets from treats. Any ideas what sizes I should order for this setup?
Tomos A35:
Black hunter exhaust pipe
Dellorto Sha 16.16 carb
15mm air intake
A55 crank
Premixing Saber 80:1
NGKB8HS spark plug
Stock top end (new piston rings)
With this setup what would my jetting range be?
Thankyou
John
Re: Jetting for this set up?
Check the spreadsheet.
Probably Fred /
Lose the 80 to one saber. run 50 to one
80 to one is for weedwackers
https://www.treatland.tv/amsoil-saber-professional-synthetic-oil-p/amsoil-saber-1-quart.htm
Read discription ^
Severe service is 50 to 1 Ratio A Modded air cooled moped is severe service/duty
John Carlile /
Saber is meant for a 100:1 one though. So 50:1 would be too rich.
Probably Fred /
> would be too rich.
Nope
amsoil synthetic 100:1 pre-mix 2-cycle oil is recommended for all water-cooled and air-cooled pre-mix applications. a mix ration of 100:1 is recommended for normal duty service in applications such as motorcycles, mopeds, outboard motors, snowmobiles, weed eaters, lawn mowers and chain saws. for "severe service" applications, richer mix ratios of 50:1 to 80:1 are recommended. these include racing motors and hot operating workhorse motors that continuously run for extended periods of time.
Read description^ it's 100 to one for weed whackers
50 to one for severe service
Kitted/modded or race air cooled moped engines are severe service/severe duty (edited)
it's a stock top end! just figure it out! def less than 80.
Get 70-80. But 74 on the dot youll be good
John Carlile /
Sweet got a 74 just waiting for some spark plugs to check it.
