ZA50 / Maxi-II / 70cc set dump
Matt Goat|Bart|no /
Yo's, im running a shit stain of a 16:16 sha, with my circuit piper, whom is a two timing hot bitch.
it's time for an upgrade, havent done moped shits in a year or 2, because motorcycles somewhat took over.
should i do boom:
https://www.treatland.tv/mikuni-20mm-carburetor-p/mikuni-20mm-vm.htm
or bam:
https://www.treatland.tv/polini-CP-19mm-carburetor-with-pull-choke-p/polini-cp-201.1900.htm
or something else, idk...let a dood know.
Re: ZA50 / Maxi-II / 70cc set dump
Probably Fred /
14mm bing way better then sha on a puch
Really I don't think that motor you got has enough...Boom or Bang...in it for either one of those choices.....a little weak, is what im saying......
Probably Fred /
Most times I'm faster with a 14mm bing on a pp kit than many phbg powered piston port kit bikes. I usually get 48 mph with quick takeoff running a 14 mm bing, tecno circuit pipe 15-17x40 gears, tuned two shoe on a e50 or
20x35 gears on a za50.
Heck I run 15mm bing, 64cc puch polini kit, estroil pipe and hit 55+
14-15 mm bings work great way more low end then a big phbg carb on a PP kit
Pipe is the limiting factor most times.
Big pipe big carb, mild pipe mild carb that's how I look at it.
