Using a stock HT Coil on the Treats CDI.
Luke “Funkenet” Hosfield /
I think my HT coil/cdi box died but I tried my other one that worked when I took it off the bike and no dice. I want to determine that it isn't my stator coils before I order a new one. Can I wire in a stock HT coil or no? How would that even work?
Red to Ht Coil
Brown to Ground
Yellow to lights
White to ?????
Re: Using a stock HT Coil on the Treats CDI.
Or is there a way I can tell if my stator coils are still good?
Totally normal JBOT /
Check voltage with the plug out and spinning the flywherl with a drill.
Should see 50-100vac between coil and ground.
