Re: Motobecane SHA 15.15 Dellorto..? or others
Graham Motzing /
well, sha's do go lean on top but that's why you gotta tune the main at WOT and use modifications to lean out the low end, although usually that is more a function of a pipe.
if you're running that hot i'd say pull timing, pull compression
the 10 cent solution might be just going to a thicker base gasket, giving you a little free porting and dropping compression a smidge. otherwise some additional de-restricting of the stock pipe might get you there, you can cut the tube or cut it shorter for the outlet nozzle snooter.
  Motobecane SHA 15.15 Dellorto..? or othersTopic by: julian schroder julian schroder 05/27/14 08:16PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Michael Sheeler Michael Sheeler 05/27/14 08:55PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: julian schroder julian schroder 05/28/14 12:38AM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Brent Bublitz Brent Bublitz 05/28/14 09:09AM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: M-Tenn Aaron M-Tenn Aaron 05/28/14 09:26AM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Mel Dyer Mel Dyer 05/28/14 09:58AM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: julian schroder julian schroder 05/28/14 07:34PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: moby mcfly moby mcfly 05/29/14 02:13PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Brent Bublitz Brent Bublitz 05/29/14 04:56PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Mel Dyer Mel Dyer 05/29/14 05:15PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: moby mcfly moby mcfly 05/29/14 05:34PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Graham Motzing Graham Motzing 05/29/14 05:55PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: brian schulz brian schulz 05/30/14 10:10AM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Graham Motzing Graham Motzing 05/30/14 10:50AM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: brian schulz brian schulz 05/30/14 12:34PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: moby mcfly moby mcfly 05/30/14 12:24PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Graham Motzing Graham Motzing 05/30/14 12:56PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: brian schulz brian schulz 05/30/14 01:04PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Brent Bublitz Brent Bublitz 05/30/14 03:47PM
