Re: Motobecane SHA 15.15 Dellorto..? or others
M-Tenn Aaron /
Replace the crank. You can then use the cheap LePartie CDI with a woodruff key and stop fucking with timing settings. The Airsal is cheaper casting than the Parmakit. With a little prep work they are close to the same.
15mm or 16mm will be fine. The stock head is fine with a gasket or polished up to run without a gasket, the stock pipe will blast but no power gain like a chamber pipe. The stock crank is like a 3musketeers candy bar. Soft as fuck on the inside.
  Motobecane SHA 15.15 Dellorto..? or othersTopic by: julian schroder julian schroder 05/27/14 08:16PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Michael Sheeler Michael Sheeler 05/27/14 08:55PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: julian schroder julian schroder 05/28/14 12:38AM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Brent Bublitz Brent Bublitz 05/28/14 09:09AM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: M-Tenn Aaron M-Tenn Aaron 05/28/14 09:26AM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Mel Dyer Mel Dyer 05/28/14 09:58AM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: julian schroder julian schroder 05/28/14 07:34PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: moby mcfly moby mcfly 05/29/14 02:13PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Brent Bublitz Brent Bublitz 05/29/14 04:56PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Mel Dyer Mel Dyer 05/29/14 05:15PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: moby mcfly moby mcfly 05/29/14 05:34PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Graham Motzing Graham Motzing 05/29/14 05:55PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: brian schulz brian schulz 05/30/14 10:10AM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Graham Motzing Graham Motzing 05/30/14 10:50AM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: brian schulz brian schulz 05/30/14 12:34PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: moby mcfly moby mcfly 05/30/14 12:24PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Graham Motzing Graham Motzing 05/30/14 12:56PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: brian schulz brian schulz 05/30/14 01:04PM
  Re: Motobecane SHA 15.15 Dellorto..? or othersRe: Brent Bublitz Brent Bublitz 05/30/14 03:47PM
