Re: Tomos A3 - help required please
Corey Sugg /
I would look into treatland.tv I believe they made a kit for the a3 do you know what mm your wrist pin is? there is a larger wrist pin and a smaller wrist pin and if you have a larger wrist pin you can use any tomos or puch kit pretty much, you can also swap over to a dell and put a pipe on it a nice filter and tune the carb. that's my thought before my a3 wiring and everything whent back on it and need a rebuild I was pulling about 40mph or so with a pipe carb and some other work done to it.
