Hi
I've recently acquired a Tomos A3ML 1989, it was a non runner. (UK Member)
I had to sort the electrics and carb out, and generally change the oils and grease/clean/de-gunk everything but I've got it started and running ok, but I need to get its performance up a touch.
I don't want to spend a massive amount on it, but I need to be able to get it up to circa 35mph on the flat.... and for it to climb smallish hills (not mountains).
Looking around on the net I can't seem to find a good supply for cheap 70cc kits here in the UK, so my thoughts go on to keeping the stock 50cc piston/barrel and then changing the gearing and exhausts/carbs etc, perhaps even do a touch of porting work?
Here's my thoughts - if I can drop on to a cheap exhaust and perhaps swap the encarwi carb for a dell'orto 17.5 (fabricate an intake) and get the gearing sorted, what can i expect from it top speed wise.... and hill climbing wise too?
Thanks in advance for any info/support you can offer....it'll be greatly appreciated.
Fabio
