Running bings backwards
Anyone do this?
I did. It works!
WHAT!
so like you can hoseclamp the little spigot mount end where the airfilter normally goes
like this:
2 ways - 1st Itook out the little centering pin from a bing, drilled a hole in the other side and set it in there so you can just turn the slide the other way, and baddaBING! it works
OR i also found this other identical sized slide, i think from an encarwi maybe, or possible a phva. it's gold. it's the same size & all but the groove for the centering pin is on the other side, so slide it right in and BING bang boom, you gotta reverse running bing. (edited)
Re: Running bings backwards
Brent Bublitz /
Why?
Probably Fred /
Here is what I did before:
I cut a intake in half then clamped it in the carb and made it into a spickot mount .
I used it as a test carb on many a bike
Dirty30 Dillon /
Does the bike have reverse now?
Brent Bublitz /
> and made it into a spigot mount .
Same here. Great way to get a normal carb on a Sachs 505 1a motor. Shoot it straight out the side.
Born to be WillD /
why? because I don't want to spend money anbd have an a55 intake on there and no spare carbs except bings and random weirdo stuff that I have no jets for. and some shas.
i've done the thing where you cut a piece of handlebar and clamp the clamp-on carbs to that, then use a hose & clamp to mount. always been curious if you could just flip a bing. you can.
Born to be WillD /
it's funny you ask. I have the cheapo CDI stator but had no magneto so I put the stock points magneto on the CDI stator, and it runs! somehow the split in the magnets or something is enough to trigger the pulse.
BUT! about 1/2 the time it fires at the wrong time, like just after TDC and so it'll run backwards.
So yes, occasionally it does in fact have reverse.
Dirty30 Dillon /
> trigger the pulse.
> backwards.
That's perfect, cuz you only want it sometimes anyways. NOW HARNESS THE POWER
not a Baron Asshole /
I accidentally timed my pug wrong and it ran backwards! even went for a short backward ride just to be silly, i couldnt figure out WTF was going on, but the Ol' le-partie needed lapping in per the wiki
depending on the moped you could prob do reverse carb too! lisdexic!
Always wondered about this topic but never got around to messing with the idea.
Born to be WillD /
yea if you just start a motor in reverse it'll often run ok in reverse.
theres a video of bobby riding a gpr revers and doing stop-wheelies (like reverse stoppie?)
the saab 2 stroke cars used to just start the motor in reverse to go in reverse.
Regardless, has very little to do with reverse carb. just thought it might be an interest worthy idea.
Dirty30 Dillon /
Now: Put a bing on the end of the pipe and run double revers-o action.
Born to be WillD /
hah! i like that idea. and the i can use the pipe as a really whacky tuned intake.
Luke “Funkenet” Hosfield /
I am hoping I can replace my Keihin on my hobbit with this idea.
Dirty30 Dillon /
OOOOOOOO Bing'ed Hobbit.
The honda purists will scoff, and we will smile.
finally, a performance tuning topic that is relevant to my interests!
> carb
> side.
Round bings fit right on 505s without an issue.
I don't get how you are supposed to add the pin to the other side of the slide hole though.
^ My immediate thought, Thank bing for the symmetry.
^if you read what Will posted he drilled the slide, and or used one from an unknown carb that worked^
Fuel screws become air screws
Air screws become fuel screws
Ashes to ashes
Dust to Dust
Amen.
well, not that a bing has either, but ya know... if it did
Born to be WillD /
sometimes true, often not. especially with the A's
Born to be WillD /
> idea.
SEE!
Born to be WillD /
also the pin that aligns the slide is just that, a little pin. it goes in a groove on the side of the carb so that the inlet side stays lined up as it moves up & down. so i pushed it out, smeared some jb weld over the hole, drilled a matching hole on the other side and put the pin in there. then the slide does the exact same thing it ever did, except faces the other way. WAM! took like 5 minutes maybe?
I also found a slide that just had the grooved slot on the opposite side and that also worked. there's no other difference in directionality (except the choke i guess but i dont need dat)
You could also cut a groove in the other side of the slide right, maybe with a hacksaw or thinner blade?
lol
'ITS JUST MOPEDS'
I don't want my slide getting stuck open at WOT.
Choke slot air leak?
Bumping this for fun. Thinking about doing this on a bike because I can’t stand a SHA that vibrates off all the time!
