Anyone do this?
I did. It works!
WHAT!
so like you can hoseclamp the little spigot mount end where the airfilter normally goes
like this:
2 ways - 1st Itook out the little centering pin from a bing, drilled a hole in the other side and set it in there so you can just turn the slide the other way, and baddaBING! it works
OR i also found this other identical sized slide, i think from an encarwi maybe, or possible a phva. it's gold. it's the same size & all but the groove for the centering pin is on the other side, so slide it right in and BING bang boom, you gotta reverse running bing. (edited)
