Where are you guys getting the rear shocks for your qt50s the one with gas adjuster etc, they look really smart, im from the uk by the way got a mallosi kit hi comp head etc. she is a beast!! Cheers.
you want 320mm with the "clevis" end for the qt
They are the ones thanks chris, been looking everywhere for them. Cheers.
Yea they do look great. Nice buy.
Scooterparts4less has them also tboltusa has a 1 & 2 inch spacer to help make it fit.
So looking at scooterparts4less, I'm gunna be stuck with having to buy a pair of shocks instead of a single shock
I purchased a pair of the shocks in the image above, they do not clear my
IRC NR-77 rubber so keep that in mind (the spring is too wide and also too soft).
Dam this tread. I have one on a suzuki. No problem
I might give these a try - a little slimmer at 2 1/8"
Holly smokes! That looks great. I'm going to find a pair for my Towny. I'll post pictures when I get them. Should I get slightly longer than stock for a bit of extra lift? You should post some pics of your rig too.
