Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?
Graham Motzing /
Sooo, 1 month ride report, rode to work every day except for 2 days i was down with a flat tire... not too shabby.
She's been holding up really well. The flat tire thing, duh. I replaced the tube in the 19 inch front, then i put a Gazelle 17x3 that i happend to have laying around on the rear. She gets loose in grass and gravel but handles on the road much better. Plus its a Gazelle, so like, invincible for running over shit. Kinda goofy with the mismatch IRC GP1 trials front, maybe i'll switch the front to Gazelle (do they make 19"?) and go full road-style on it.
Spokes have been an issue, the spoke nuts are all rusted.. probably had 2 flat tires with water sitting in them because all the rusty spokes are on one side of each tire... bummer... broke one, rear is a bit out of true, but not too bad.
So my commute is about 5-6 miles of stop-and-go city traffic, then 15 or so miles of wide open with occasional stop light. She doesn't mind the wide open on the way into work, but when she has to do stop-and-go after being held WOT for 20 minutes, the clutch gets a bit cranky.
I switched over to 20w50 - castrol semi-synthetic with the cruiser picture on the bottle- and that has improved clutching significantly. My clutch pressure plate is also warped ever so slightly, so it drags and shifting is a bit notchy once she gets hot. I might move up to a gear oil, because clutch slip hasn't been an issue at all, or maybe try a full-syn 20w-50... the scratch on the crank seal bushing has resulted in it eating about 400ml of oil over the last month (not a big amount, but scary when you only have 750 ml total in the 'case) and i got a wierd grinding bearing noise when it got too low to lube the trans shaft. Put in more oil and the noise has completely gone away, i think it was just a free-running gear on the shaft that was rattling rather than a spun bearing... Took the case apart and no shine in the oil.
Anyhow... running wot at 55 mph, she seems ok but the top end just isn't there. I found an old post of Roald's where he says the pipe and silencer is restricted. The pipe chokes pretty abruptly right at 10,5k rpm, and there isn't much power over 9,5 (and no power under 7k) so I'm thinking about adding a pipe. The DT pipes are all for either the older engine (screw flange) or the newer AM6 motor, so i'm thinking about one of the cheap <150$ NSR pipes, since all the GPR/AM6 pipes are 200++
Anyhow, the longer i ride it the more i'm liking it. Once you get used to riding the clutch and stomp shifting, its not bad... Kinda like... learn to love the bomb ya know. She smooths out beautifully at 11k rpm, which i hit going downhill a couple times into work, so i think bigger carb, bigger reeds and the pipe would let me stay in the porting better. With 180+ exhaust duration, you can just feel the engine wanting to pull, but getting shut down because the pipe is too long and restrictive for the cylinder.
I could probably get a cheap boost just by bending out the reed stops, but they are steel and i really really don't want to shred them.
Its always like, get a bike, its stock, get it running good... buuuut... its just not quite fast enough... so you start adding shit, pretty soon you've got an time bomb screamer that shreds parts constantly ends up breaking something major, and you park it... damn... already going down the rabbit hole! Seriously though, this cylinder is ported to rev 12, 14k all day long and the trans, bearings, and everything else are set to handle it, but they have this shitty pipe that chokes it at 10,5... having no power on the bottom end, it just makes the power band too narrow. I don't think it can get any worse bottom end by adding a pipe... maybe i'll build one of j-bot's boners and use one of those trick magura choke sliders with the NSR pipe...
fun fun fun...
  NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Topic by: Doug Wilhelm Doug Wilhelm 01/17/14 10:07PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Leo Heyman Leo Heyman 01/17/14 10:09PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: RADIUM CITY JO$HUA RADIUM CITY JO$HUA 01/17/14 10:26PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Kevin Bishop Kevin Bishop 01/18/14 11:56AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Steven Dewaele Steven Dewaele 01/18/14 01:47PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: G _ G _ 01/18/14 02:11PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 01/18/14 02:19PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 01/18/14 02:20PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Matt Spriedejs Matt Spriedejs 01/18/14 04:55PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Princess Rapunzel Princess Rapunzel 02/16/14 03:43PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/16/14 08:11PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 01/18/14 07:04PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: joe muncey joe muncey 01/19/14 02:34AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: R B R B 01/19/14 11:35AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 01/19/14 04:12PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: G _ G _ 01/19/14 03:05PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Blake MD No PM Plz Blake MD No PM Plz 01/19/14 07:06PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 01/19/14 04:10PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Deadped Ryan Deadped Ryan 01/19/14 05:32PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 01/19/14 05:41PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 01/22/14 01:13PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 01/22/14 01:18PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 01/22/14 02:39PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 01/22/14 06:37PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 01/22/14 11:22PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 01/22/14 01:16PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 01/22/14 11:36PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 01/23/14 09:43AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 01/23/14 09:48AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 01/23/14 09:58AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 01/23/14 10:06AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Tummy Sticks 420 Blazit Tummy Sticks 420 Blazit 01/23/14 10:01AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 01/23/14 11:38AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: d. Hathorn d. Hathorn 01/24/14 03:01AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 01/27/14 12:35AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Blake MD No PM Plz Blake MD No PM Plz 01/27/14 01:38AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 01/27/14 10:01AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 01/27/14 12:40AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 01/27/14 10:09AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 01/27/14 01:50PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 01/27/14 02:32PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 01/27/14 09:45PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 01/27/14 09:50PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 02/02/14 12:45PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/03/14 01:28PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 02/03/14 06:56PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/03/14 11:38PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 02/04/14 09:35AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/04/14 09:40AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Born to be WillD Born to be WillD 02/04/14 05:12PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 02/04/14 09:04PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/05/14 10:35AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 02/15/14 05:21PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 02/15/14 07:14PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/16/14 01:48PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Carlos Rosario Carlos Rosario 11/11/16 05:27AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 11/16/16 03:07PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 11/16/16 04:05PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 11/16/16 04:55PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 11/18/16 10:31AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 11/19/16 02:05AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LSLB RXb LSLB RXb 11/19/16 02:08AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Blake MD No PM Plz Blake MD No PM Plz 11/19/16 10:14AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Rob Rob Rob Rob 11/22/16 11:31PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 02/16/14 10:43PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/17/14 09:31AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 02/17/14 10:42AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 02/17/14 11:49AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 02/17/14 12:00PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 02/17/14 01:35PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 02/17/14 02:25PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Deadped Ryan Deadped Ryan 02/17/14 08:29PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/18/14 10:01AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 02/18/14 12:57PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/18/14 01:02PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 02/18/14 10:46AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Born to be WillD Born to be WillD 02/18/14 12:18PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 02/18/14 06:00PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/19/14 11:53AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 02/19/14 01:38PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 02/19/14 03:30PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 03/01/14 09:47AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 03/04/14 10:04AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 03/05/14 08:58PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 03/05/14 10:29PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 03/05/14 11:21PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 03/17/14 12:31AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 03/17/14 10:23AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 03/17/14 10:53AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 03/25/14 10:23AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 03/25/14 10:38AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 03/25/14 11:27AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 03/25/14 11:55AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 03/25/14 11:58AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 03/25/14 12:45PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 03/25/14 11:57PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 03/26/14 11:04AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 03/26/14 11:07AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 03/26/14 01:05PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 03/31/14 02:43PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 03/31/14 02:48PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Born to be WillD Born to be WillD 04/17/14 03:05PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 03/26/14 11:41AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Born to be WillD Born to be WillD 03/26/14 01:03PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 03/31/14 06:43PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 03/31/14 07:57PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 03/31/14 08:07PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 03/31/14 08:10PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 03/31/14 08:14PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 03/31/14 08:17PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 03/31/14 08:25PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 03/31/14 08:33PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 03/31/14 09:21PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 04/01/14 10:42AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 04/01/14 12:02PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 04/01/14 02:21PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 04/02/14 10:09AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 04/02/14 12:32PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 04/16/14 05:26PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 04/17/14 11:08AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Derek Stahl Derek Stahl 04/17/14 12:19PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 05/02/14 04:31PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 05/02/14 04:39PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 05/02/14 06:38PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 05/02/14 10:44PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 05/13/14 09:05AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 05/13/14 09:45AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 05/13/14 11:17PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 05/14/14 09:59AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 05/18/14 11:18PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 05/18/14 11:21PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 05/18/14 11:26PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 09/01/15 04:22PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 05/19/14 08:57AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 05/19/14 09:46AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 05/19/14 10:02AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 05/27/14 03:34PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 06/20/14 11:40AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: LL danktip LL danktip 06/20/14 03:11PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 06/20/14 11:23PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 11/03/14 08:00PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 11/03/14 09:59PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: † CH∆D † † CH∆D † 11/03/14 10:23PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Mike Boyd Mike Boyd 09/01/15 06:00PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: niklaus _ niklaus _ 09/01/15 10:29PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 09/01/15 10:32PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/01/15 07:47PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: river 2strokes river 2strokes 09/01/15 08:09PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Rob Rob Rob Rob 11/22/16 11:21PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 11/23/16 09:47AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 11/23/16 12:48AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Rob Rob Rob Rob 11/23/16 02:15PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 11/23/16 02:21PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Rob Rob Rob Rob 11/23/16 03:30PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 11/23/16 04:15PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 12/06/16 03:43PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Blake MD No PM Plz Blake MD No PM Plz 12/06/16 04:07PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Blake MD No PM Plz Blake MD No PM Plz 12/07/16 05:45PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 12/18/16 08:57PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 12/28/16 04:54PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 02/27/17 09:54PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/28/17 01:00AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 02/28/17 11:52AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/28/17 03:05PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 02/28/17 04:53PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 02/28/17 05:25PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 02/28/17 06:27PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 03/01/17 10:12AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 03/03/17 04:42AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 03/03/17 10:06AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 03/03/17 04:36PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 03/03/17 05:41PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 03/03/17 06:20PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Cole Doubt Cole Doubt 03/04/17 12:55AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 03/04/17 10:58AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Doug Wilhelm Doug Wilhelm 03/04/17 02:51PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 03/05/17 04:15PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 03/18/17 12:17AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 03/18/17 04:37AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 03/19/17 08:24PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 03/20/17 09:41AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 03/21/17 04:39PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 03/21/17 05:05PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 04/01/17 05:36PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 04/02/17 06:02PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 04/04/17 09:13PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 04/04/17 11:39PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: river 2strokes river 2strokes 04/05/17 08:15AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 04/09/17 10:26PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: river 2strokes river 2strokes 04/05/17 09:12AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 04/05/17 09:47AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 04/05/17 11:11AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: river 2strokes river 2strokes 04/05/17 10:44AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: river 2strokes river 2strokes 04/05/17 12:06PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: river 2strokes river 2strokes 04/10/17 08:46AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 04/10/17 04:10PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 05/09/17 09:35PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: river 2strokes river 2strokes 04/10/17 11:54AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 07/31/17 10:11AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 07/31/17 03:14PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 07/31/17 03:31PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 07/31/17 09:08PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: river 2strokes river 2strokes 07/31/17 10:21PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 07/31/17 11:04PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: jayson sumpter jayson sumpter 08/01/17 08:54AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: river 2strokes river 2strokes 08/01/17 09:09AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 09/08/17 10:30AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 10/03/17 10:15PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 10/04/17 09:34AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 10/04/17 10:27AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 11/07/17 11:59PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Get Blatzed Get Blatzed 12/04/18 04:05AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 12/04/18 09:47AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 12/04/18 11:26AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 12/04/18 04:47PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 12/04/18 04:31PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 12/04/18 09:22PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 12/05/18 03:02PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Get Blatzed Get Blatzed 12/06/18 12:20AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 12/06/18 12:14PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 12/06/18 02:13PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Get Blatzed Get Blatzed 12/05/18 12:58AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 12/05/18 09:41AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 12/06/18 02:27PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 12/06/18 02:50PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 12/07/18 09:30AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 12/07/18 10:57AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 12/06/18 03:59PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 12/06/18 04:43PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 12/06/18 05:53PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 12/06/18 09:17PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 12/07/18 09:11AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 12/09/18 06:58PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: P D P D 12/09/18 07:07PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dave & Bummerzz Dave & Bummerzz 12/11/18 09:29AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Graham Motzing Graham Motzing 12/11/18 09:55AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: P D P D 12/11/18 11:30AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 12/11/18 07:20PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Lee Hoffguy Lee Hoffguy 12/11/18 06:59PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 12/11/18 09:33PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Chöschi21 C.K. Chöschi21 C.K. 12/07/18 05:25PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Ryan Graeme Ryan Graeme 12/08/18 03:22AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/11/18 11:37AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: P D P D 12/11/18 11:51AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Dirty30 Dillon Dirty30 Dillon 12/11/18 02:49PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Get Blatzed Get Blatzed 12/12/18 01:37AM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: K H K H 12/13/18 06:11PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Yung Spil Yung Spil 03/09/19 06:57PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 03/09/19 07:11PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: ck 🌧🌧🌧 ck 🌧🌧🌧 11/17/19 01:52PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Daniel '' Daniel '' 11/17/19 04:22PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: ck 🌧🌧🌧 ck 🌧🌧🌧 11/17/19 05:16PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: Nick MBC Nick MBC 11/17/19 07:20PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: ck 🌧🌧🌧 ck 🌧🌧🌧 11/17/19 07:59PM
  Re: NOT-A-MOPED: 1988 Yamaha DT50... Thoughts?Re: «tyler » «tyler » 01/18/14 12:38PM
