super bored... euro sachs pics/info thoughts
Here's a late model euro style B jug for sachs. it's a "BX" and is common on the euro 2 speed manuals.
square jug, but "B" restricted.
note the weird segmented removeable transfer walls. odd. Also, tiny restricted exhaust, flat port exhaust mount and flat-to-angled intake port & adapter.
also they came w single ring piston & 44mm (long D-length) crank but are restricted heavily for 30kph.
here's a euro late-model D, besnik was just talking about this coming on a Portuguese SIS w/ sachs motor
It's a "DS" or "DK" designation (the K was for kickstart sachs - same topend)
notice the single ring piston, flat intake and exhaust ports, groove in the fins around where the head would separate
nice trannies, BIG exhaust
enjoy this worthless info.(edited)
Re: super bored... euro sachs pics/info thoughts
Kevin Bishop /
That ds cylinder intake looks 50% bigger than d cylinder what size intake does it have. why no pic of the exhaust?
thanks for the info will. sachs info is pretty hard to find. usually because no one cares about sachs stuff
damn that's a tiny exhaust window
Charles Cole (OFMC) /
Looks like a lot of room for improvement.
LOOK WHAT I FOUND! Slapped down $30 on this rare piece of Sachs performance :)
I have the Ds on my 85 Sachs taxi sweet stock 32 mph.
The taxi has stock forward faced intake and air box.
Taxi also has a mini expansion chamber on the exhaust header.
I have the austisa too
got it used at handybikes for $12
then snagged the piston from treats
Luv the Sachs
We had an autisa on a 505/1a once, andres swoops. he rode it for a while. it was always geared rather low, but screamed to 40's. it was pretty comparable to the athena 70 but revved higher
the forward intake rules, i shoulda snapped a photo of that, i got one on my prima.
oh and here's the exhaust on the DS
not fully utilized, and huge mount bolts, still impressive.
(edited)
What is the point of segmented transfer walls?
Turbulence for less performance?
> mph.
> box.
> exhaust header.
> Luv the Sachs
Might I ask which piston you used? Gotta get one. The kit is 42mm correct so was looking at using a modified Athena 42mm one.
Kevin Bishop /
I like how the exhaust gives you more options than the 25mm id of stock d, and not a slip on.
There are 3 SIS sachs saxi's on ebay in ohio all with that DS jug
> with that DS jug
I feel as thoigh 2014 will be years of the Sachses...!
Kevin Bishop /
You got a link will all I could find was moped motion junk.
> motion junk.
http://m.ebay.com/itm/111202212232?nav=SEARCH&sbk=1
