Tomos A35 Air Leak
Ryan Daniels /
Just wanted to throw this out to the masses that know more than I do. I've been trying to eliminate an air leak from an a35 I bought non-running. I've used different cylinder, head, and gasket combinations as well as making sure to use proper torque on the nuts. Spraying carb cleaner between the cylinder and head consistently kills the engine. Any other ideas as to what might be happening? Also new studs.
Re: Tomos A35 Air Leak
good flat base gasket
they do make and sell head gasket when I use them I spray them with copper gasket in a airsal can(good stuff for every thing)
crank seal, magneto side ?
