Re: Tomos a35 Hammer
not a Baron Asshole /
Seeing ive exploded more clutches than most here(12? 1st gears), Ill definitely agree with 1st gear is only needed. Ive kept most of the exploded ones and yes around the pins, but usually because a35's(and same design on 55's) have only 1MM cross section where they shear off from force. The a3's design is literally double at 2mm and last with real clutch material(light mods needed) They are still only CAST(failure) aluminum.
Some designers in Europe have redesigned the bell but i feel it very unnecessary, and would add lots of cost(and weight) Yes i have killed one before, but only because the clutch came apart and hurled into the bell in a very non-concentric manner.
I keep usually 2 extra sets of kevlar lined 1st gear setups most of the time(second gear doesn't even need that)and strong springs 15-20lbs depending on fluid and how much power i am setting them up for. I also have stock ones and a crank with bell if you need for the setup and tooling. The splines aren't weak at all, ive seen a few failures, always are due to people not using the correct washers and lack of thread locker, and loose to ruin the splines.
PM me for info
Pete
  Tomos a35 HammerTopic by: Zarä Julia Zarä Julia 07/16/13 05:23PM
  Re: Tomos a35 HammerRe: Saabsonettguy . Saabsonettguy . 07/16/13 05:33PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/16/13 05:38PM
  Re: Tomos a35 HammerRe: Pablo Puchasso Pablo Puchasso 07/16/13 06:55PM
  Re: Tomos a35 HammerRe: Bobby Cazeault Bobby Cazeault 07/16/13 10:27PM
  Re: Tomos a35 HammerRe: Totally normal JBOT Totally normal JBOT 07/16/13 10:52PM
  Re: Tomos a35 HammerRe: Josh Cranston Josh Cranston 07/16/13 11:12PM
  Re: Tomos a35 HammerRe: _ olazy _ olazy 07/17/13 01:49PM
  Re: Tomos a35 HammerRe: Mo Peds Mo Peds 07/17/13 03:00PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   07/17/13 03:46PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/17/13 06:01PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   07/17/13 10:51PM
  Re: Tomos a35 HammerRe: mattology - mattology - 07/18/13 02:14PM
  Re: Tomos a35 HammerRe: Max (ツ) Max (ツ) 07/18/13 03:09PM
  Re: Tomos a35 HammerRe: DAM JakeM DAM JakeM 07/18/13 03:15PM
  Re: Tomos a35 HammerRe: Bryan Colliver Bryan Colliver 07/18/13 05:50PM
  Re: Tomos a35 HammerRe: Bobby Cazeault Bobby Cazeault 07/18/13 06:47PM
  Re: Tomos a35 HammerRe: Adam Klags MPG Adam Klags MPG 07/18/13 09:18PM
  Re: Tomos a35 HammerRe: Adam Klags MPG Adam Klags MPG 07/18/13 09:31PM
  Re: Tomos a35 HammerRe: will warn will warn 07/18/13 11:39PM
  Re: Tomos a35 HammerRe: mattology - mattology - 07/19/13 01:44AM
  Re: Tomos a35 HammerRe: One Chris G 📉⚰️ One Chris G 📉⚰️ 08/21/14 02:35PM
  Re: Tomos a35 HammerRe: Born to be WillD Born to be WillD 07/19/13 03:25PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/19/13 05:40PM
  Re: Tomos a35 HammerRe: Josh Cranston Josh Cranston 07/19/13 10:19PM
  Re: Tomos a35 HammerRe: not a Baron Asshole not a Baron Asshole 07/20/13 08:51PM
  Re: Tomos a35 HammerRe: mattology - mattology - 07/21/13 11:18PM
  Re: Tomos a35 HammerRe: King Drunky JCams King Drunky JCams 07/22/13 05:18PM
  Re: Tomos a35 HammerRe: DAM" Michael " DAM" Michael " 07/22/13 06:26PM
  Re: Tomos a35 HammerRe: Adam Klags MPG Adam Klags MPG 07/22/13 09:14PM
  Re: Tomos a35 HammerRe: Johnny fucker Johnny fucker 07/23/13 12:20AM
  Re: Tomos a35 HammerRe: JOE PEG JOE PEG 07/23/13 12:42AM
  Re: Tomos a35 HammerRe: Full Tuck Full Tuck 07/23/13 11:55PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/24/13 01:07AM
  Re: Tomos a35 HammerRe: Adam Klags MPG Adam Klags MPG 07/24/13 07:32AM
  Re: Tomos a35 HammerRe: sean davis sean davis 07/26/13 05:15PM
  Re: Tomos a35 HammerRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/27/13 11:28AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/27/13 11:57PM
  Re: Tomos a35 HammerRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/28/13 12:12AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/28/13 12:16AM
  Re: Tomos a35 HammerRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/28/13 12:55AM
  Re: Tomos a35 HammerRe: D .o D .o 09/22/13 06:40PM
  Re: Tomos a35 HammerRe: Josh Cranston Josh Cranston 01/04/14 12:40AM
  Re: Tomos a35 HammerRe: preeesh . preeesh . 01/06/14 03:28PM
  Re: Tomos a35 HammerRe: Full Tuck Full Tuck 01/04/14 09:49AM
  Re: Tomos a35 HammerRe: Daniel '' Daniel '' 01/06/14 05:22PM
  Re: Tomos a35 HammerRe: Johnny fucker Johnny fucker 01/06/14 09:28PM
  Re: Tomos a35 HammerRe: Adam Klags MPG Adam Klags MPG 01/06/14 10:26PM
  Re: Tomos a35 HammerRe: Lia the Raven Lia the Raven 01/07/14 01:55PM
  Re: Tomos a35 HammerRe: Jesse Stephenson Jesse Stephenson 01/07/14 04:51PM
  Re: Tomos a35 HammerRe: Graham Motzing Graham Motzing 01/07/14 05:42PM
  Re: Tomos a35 HammerRe: Jesse Stephenson Jesse Stephenson 01/07/14 06:22PM
  Re: Tomos a35 HammerRe: Jake P Jake P 01/08/14 01:52AM
  Re: Tomos a35 HammerRe: DAM JakeM DAM JakeM 01/07/14 06:58PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 01/08/14 11:08PM
  Re: Tomos a35 HammerRe: Josh Cranston Josh Cranston 01/09/14 12:16PM
  Re: Tomos a35 HammerRe: Weak-Ends Tj Weak-Ends Tj 02/02/14 03:46PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/02/14 04:25PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   02/03/14 01:14AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/03/14 01:42AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/12/14 12:27PM
  Re: Tomos a35 HammerRe: Jedd Goblin Jedd Goblin 02/12/14 12:53PM
  Re: Tomos a35 HammerRe: Weak-Ends Tj Weak-Ends Tj 02/12/14 07:48PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   02/12/14 10:05PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/12/14 10:15PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   02/12/14 10:24PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/12/14 11:02PM
  Re: Tomos a35 HammerRe: mattology - mattology - 02/13/14 12:06AM
  Re: Tomos a35 HammerRe: Jeremy Husk Jeremy Husk 02/13/14 11:47AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/13/14 11:51AM
  Re: Tomos a35 HammerRe: Jeremy Husk Jeremy Husk 02/13/14 01:32PM
  Re: Tomos a35 HammerRe: Lazy Pedaler Lazy Pedaler 02/16/14 03:20PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/16/14 03:27PM
  Re: Tomos a35 HammerRe: Jeremy Husk Jeremy Husk 02/16/14 04:18PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/05/14 04:11PM
  Re: Tomos a35 HammerRe: niklaus _ niklaus _ 08/05/14 05:42PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   08/07/14 07:25PM
  Re: Tomos a35 HammerRe: Daniel '' Daniel '' 08/07/14 08:57PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/07/14 09:01PM
  Re: Tomos a35 HammerRe: Michael Thomas Michael Thomas 08/05/14 04:13PM
  Re: Tomos a35 HammerRe: Max Johnson Max Johnson 08/05/14 06:21PM
  Re: Tomos a35 HammerRe: Max Johnson Max Johnson 08/07/14 10:40PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/07/14 10:43PM
  Re: Tomos a35 HammerRe: Max Johnson Max Johnson 08/07/14 10:50PM
  Re: Tomos a35 HammerRe: mit mortso mit mortso 08/08/14 02:36AM
  Re: Tomos a35 HammerRe: mit mortso mit mortso 08/08/14 02:37AM
  Re: Tomos a35 HammerRe: Lia the Raven Lia the Raven 08/10/14 09:57PM
  Re: Tomos a35 HammerRe: Probably Fred Probably Fred 08/11/14 12:25PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/11/14 09:56PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/12/14 12:21AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/13/14 03:32PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   08/16/14 02:43PM
  Re: Tomos a35 HammerRe: campeona del mundo campeona del mundo 08/16/14 10:30PM
  Re: Tomos a35 HammerRe: will warn will warn 08/17/14 03:20AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/18/14 04:57PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   08/19/14 04:26PM
  Re: Tomos a35 HammerRe: mattology - mattology - 08/19/14 06:01PM
  Re: Tomos a35 HammerRe: Brock Croy Brock Croy 02/11/15 12:11AM
  Re: Tomos a35 HammerRe: Emerica   Emerica   08/19/14 07:05PM
  Re: Tomos a35 HammerRe: Josh Cranston Josh Cranston 08/19/14 07:07PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   08/20/14 12:05AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/27/14 10:46PM
  Re: Tomos a35 HammerRe: Rick McNerney Rick McNerney 08/28/14 10:50AM
  Re: Tomos a35 HammerRe: Kim Jong illest Kim Jong illest 08/28/14 02:05AM
  Re: Tomos a35 HammerRe: Brandon Love Brandon Love 08/28/14 08:14AM
  Re: Tomos a35 HammerRe: Mo Peds Mo Peds 08/28/14 10:37AM
  Re: Tomos a35 HammerRe: will warn will warn 08/28/14 02:26PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   08/28/14 01:51PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/29/14 12:10AM
  Re: Tomos a35 HammerRe: Rick McNerney Rick McNerney 10/29/14 07:28AM
  Re: Tomos a35 HammerRe: will warn will warn 08/29/14 05:23PM
  Re: Tomos a35 HammerRe: Jesse Stephenson Jesse Stephenson 08/30/14 02:58PM
  Re: Tomos a35 HammerRe: jeffrey Suarez jeffrey Suarez 02/11/15 12:04PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/15/15 04:14PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/22/15 10:05AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 11/09/15 04:10PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 11/09/15 09:01PM
  Re: Tomos a35 HammerRe: Dave Steele Dave Steele 12/06/15 10:53AM
  Re: Tomos a35 HammerRe: Jonathan Eaton Jonathan Eaton 12/06/15 07:54PM
  Re: Tomos a35 HammerRe: Jonathan Eaton Jonathan Eaton 12/06/15 08:28PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 12/08/15 07:52PM
  Re: Tomos a35 HammerRe: Roger Suarez Roger Suarez 12/09/15 12:25AM
