Re: Tomos a35 Hammer
Max (ツ) /
it's been a while, but i used to have a really nice shifting motor setup
1st
very light first gear shoes and high spring tension for high engagement and light shoes for smooth, slippery engagement
2nd
stock second gear because i wanted it to engage 100% and not slip. the weight is what gets you solid positive engagement. then you can set the speed it shifts at pretty accurately with spring tension
Series of events that took place:
first gear shoes are fixed directly to the crank
first gear spins up and slips/engages on the bell
first gear engages the bell 100% and revs build
the motion of the bell spins up the second gear clutch and it engages the bell
the decrease in rpm breaks the first gear shoes free from the bell and first gear slips while second gear is 100% engaged. this allows for a feathered clutch feel in second gear that keeps you in the powerband.
I'm sure you could achieve the same feel with 2 special clutches, but you can make it happen with only one
this is all based on sound, feel, and lots of experimentation but there's definitely the possibility i have it all wrong.
as i understand it, (and the basis for the above) when you're rapped out in second gear, power is being trasfered from:
crank -> 1st shoes -> bell -> second shoes -> reduction
  Tomos a35 HammerTopic by: Zarä Julia Zarä Julia 07/16/13 05:23PM
  Re: Tomos a35 HammerRe: Saabsonettguy . Saabsonettguy . 07/16/13 05:33PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/16/13 05:38PM
  Re: Tomos a35 HammerRe: Pablo Puchasso Pablo Puchasso 07/16/13 06:55PM
  Re: Tomos a35 HammerRe: Bobby Cazeault Bobby Cazeault 07/16/13 10:27PM
  Re: Tomos a35 HammerRe: Totally normal JBOT Totally normal JBOT 07/16/13 10:52PM
  Re: Tomos a35 HammerRe: Josh Cranston Josh Cranston 07/16/13 11:12PM
  Re: Tomos a35 HammerRe: _ olazy _ olazy 07/17/13 01:49PM
  Re: Tomos a35 HammerRe: Mo Peds Mo Peds 07/17/13 03:00PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   07/17/13 03:46PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/17/13 06:01PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   07/17/13 10:51PM
  Re: Tomos a35 HammerRe: mattology - mattology - 07/18/13 02:14PM
  Re: Tomos a35 HammerRe: Max (ツ) Max (ツ) 07/18/13 03:09PM
  Re: Tomos a35 HammerRe: DAM JakeM DAM JakeM 07/18/13 03:15PM
  Re: Tomos a35 HammerRe: Bryan Colliver Bryan Colliver 07/18/13 05:50PM
  Re: Tomos a35 HammerRe: Bobby Cazeault Bobby Cazeault 07/18/13 06:47PM
  Re: Tomos a35 HammerRe: Adam Klags MPG Adam Klags MPG 07/18/13 09:18PM
  Re: Tomos a35 HammerRe: Adam Klags MPG Adam Klags MPG 07/18/13 09:31PM
  Re: Tomos a35 HammerRe: will warn will warn 07/18/13 11:39PM
  Re: Tomos a35 HammerRe: mattology - mattology - 07/19/13 01:44AM
  Re: Tomos a35 HammerRe: One Chris G 📉⚰️ One Chris G 📉⚰️ 08/21/14 02:35PM
  Re: Tomos a35 HammerRe: Born to be WillD Born to be WillD 07/19/13 03:25PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/19/13 05:40PM
  Re: Tomos a35 HammerRe: Josh Cranston Josh Cranston 07/19/13 10:19PM
  Re: Tomos a35 HammerRe: not a Baron Asshole not a Baron Asshole 07/20/13 08:51PM
  Re: Tomos a35 HammerRe: mattology - mattology - 07/21/13 11:18PM
  Re: Tomos a35 HammerRe: King Drunky JCams King Drunky JCams 07/22/13 05:18PM
  Re: Tomos a35 HammerRe: DAM" Michael " DAM" Michael " 07/22/13 06:26PM
  Re: Tomos a35 HammerRe: Adam Klags MPG Adam Klags MPG 07/22/13 09:14PM
  Re: Tomos a35 HammerRe: Johnny fucker Johnny fucker 07/23/13 12:20AM
  Re: Tomos a35 HammerRe: JOE PEG JOE PEG 07/23/13 12:42AM
  Re: Tomos a35 HammerRe: Full Tuck Full Tuck 07/23/13 11:55PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/24/13 01:07AM
  Re: Tomos a35 HammerRe: Adam Klags MPG Adam Klags MPG 07/24/13 07:32AM
  Re: Tomos a35 HammerRe: sean davis sean davis 07/26/13 05:15PM
  Re: Tomos a35 HammerRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/27/13 11:28AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/27/13 11:57PM
  Re: Tomos a35 HammerRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/28/13 12:12AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/28/13 12:16AM
  Re: Tomos a35 HammerRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/28/13 12:55AM
  Re: Tomos a35 HammerRe: D .o D .o 09/22/13 06:40PM
  Re: Tomos a35 HammerRe: Josh Cranston Josh Cranston 01/04/14 12:40AM
  Re: Tomos a35 HammerRe: preeesh . preeesh . 01/06/14 03:28PM
  Re: Tomos a35 HammerRe: Full Tuck Full Tuck 01/04/14 09:49AM
  Re: Tomos a35 HammerRe: Daniel '' Daniel '' 01/06/14 05:22PM
  Re: Tomos a35 HammerRe: Johnny fucker Johnny fucker 01/06/14 09:28PM
  Re: Tomos a35 HammerRe: Adam Klags MPG Adam Klags MPG 01/06/14 10:26PM
  Re: Tomos a35 HammerRe: Lia the Raven Lia the Raven 01/07/14 01:55PM
  Re: Tomos a35 HammerRe: Jesse Stephenson Jesse Stephenson 01/07/14 04:51PM
  Re: Tomos a35 HammerRe: Graham Motzing Graham Motzing 01/07/14 05:42PM
  Re: Tomos a35 HammerRe: Jesse Stephenson Jesse Stephenson 01/07/14 06:22PM
  Re: Tomos a35 HammerRe: Jake P Jake P 01/08/14 01:52AM
  Re: Tomos a35 HammerRe: DAM JakeM DAM JakeM 01/07/14 06:58PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 01/08/14 11:08PM
  Re: Tomos a35 HammerRe: Josh Cranston Josh Cranston 01/09/14 12:16PM
  Re: Tomos a35 HammerRe: Weak-Ends Tj Weak-Ends Tj 02/02/14 03:46PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/02/14 04:25PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   02/03/14 01:14AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/03/14 01:42AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/12/14 12:27PM
  Re: Tomos a35 HammerRe: Jedd Goblin Jedd Goblin 02/12/14 12:53PM
  Re: Tomos a35 HammerRe: Weak-Ends Tj Weak-Ends Tj 02/12/14 07:48PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   02/12/14 10:05PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/12/14 10:15PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   02/12/14 10:24PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/12/14 11:02PM
  Re: Tomos a35 HammerRe: mattology - mattology - 02/13/14 12:06AM
  Re: Tomos a35 HammerRe: Jeremy Husk Jeremy Husk 02/13/14 11:47AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/13/14 11:51AM
  Re: Tomos a35 HammerRe: Jeremy Husk Jeremy Husk 02/13/14 01:32PM
  Re: Tomos a35 HammerRe: Lazy Pedaler Lazy Pedaler 02/16/14 03:20PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/16/14 03:27PM
  Re: Tomos a35 HammerRe: Jeremy Husk Jeremy Husk 02/16/14 04:18PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/05/14 04:11PM
  Re: Tomos a35 HammerRe: niklaus _ niklaus _ 08/05/14 05:42PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   08/07/14 07:25PM
  Re: Tomos a35 HammerRe: Daniel '' Daniel '' 08/07/14 08:57PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/07/14 09:01PM
  Re: Tomos a35 HammerRe: Michael Thomas Michael Thomas 08/05/14 04:13PM
  Re: Tomos a35 HammerRe: Max Johnson Max Johnson 08/05/14 06:21PM
  Re: Tomos a35 HammerRe: Max Johnson Max Johnson 08/07/14 10:40PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/07/14 10:43PM
  Re: Tomos a35 HammerRe: Max Johnson Max Johnson 08/07/14 10:50PM
  Re: Tomos a35 HammerRe: mit mortso mit mortso 08/08/14 02:36AM
  Re: Tomos a35 HammerRe: mit mortso mit mortso 08/08/14 02:37AM
  Re: Tomos a35 HammerRe: Lia the Raven Lia the Raven 08/10/14 09:57PM
  Re: Tomos a35 HammerRe: Probably Fred Probably Fred 08/11/14 12:25PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/11/14 09:56PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/12/14 12:21AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/13/14 03:32PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   08/16/14 02:43PM
  Re: Tomos a35 HammerRe: campeona del mundo campeona del mundo 08/16/14 10:30PM
  Re: Tomos a35 HammerRe: will warn will warn 08/17/14 03:20AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/18/14 04:57PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   08/19/14 04:26PM
  Re: Tomos a35 HammerRe: mattology - mattology - 08/19/14 06:01PM
  Re: Tomos a35 HammerRe: Brock Croy Brock Croy 02/11/15 12:11AM
  Re: Tomos a35 HammerRe: Emerica   Emerica   08/19/14 07:05PM
  Re: Tomos a35 HammerRe: Josh Cranston Josh Cranston 08/19/14 07:07PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   08/20/14 12:05AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/27/14 10:46PM
  Re: Tomos a35 HammerRe: Rick McNerney Rick McNerney 08/28/14 10:50AM
  Re: Tomos a35 HammerRe: Kim Jong illest Kim Jong illest 08/28/14 02:05AM
  Re: Tomos a35 HammerRe: Brandon Love Brandon Love 08/28/14 08:14AM
  Re: Tomos a35 HammerRe: Mo Peds Mo Peds 08/28/14 10:37AM
  Re: Tomos a35 HammerRe: will warn will warn 08/28/14 02:26PM
  Re: Tomos a35 HammerRe: Emerica   Emerica   08/28/14 01:51PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 08/29/14 12:10AM
  Re: Tomos a35 HammerRe: Rick McNerney Rick McNerney 10/29/14 07:28AM
  Re: Tomos a35 HammerRe: will warn will warn 08/29/14 05:23PM
  Re: Tomos a35 HammerRe: Jesse Stephenson Jesse Stephenson 08/30/14 02:58PM
  Re: Tomos a35 HammerRe: jeffrey Suarez jeffrey Suarez 02/11/15 12:04PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 02/15/15 04:14PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 07/22/15 10:05AM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 11/09/15 04:10PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 11/09/15 09:01PM
  Re: Tomos a35 HammerRe: Dave Steele Dave Steele 12/06/15 10:53AM
  Re: Tomos a35 HammerRe: Jonathan Eaton Jonathan Eaton 12/06/15 07:54PM
  Re: Tomos a35 HammerRe: Jonathan Eaton Jonathan Eaton 12/06/15 08:28PM
  Re: Tomos a35 HammerRe: Zarä Julia Zarä Julia 12/08/15 07:52PM
  Re: Tomos a35 HammerRe: Roger Suarez Roger Suarez 12/09/15 12:25AM
