Making Peugeot take off at higher revs
I'm just curious, anyone will tell you to remove 3 balls from pug clutch and add an extra spring to make it take off at higher revs. But what about the starter clutch? I mean, it's bound to catch at no more than 3-4 mph, or you wouldn't be able to push start the bike.
So that's what I am experiencing, I can remove the balls and install the 2nd spring, so the bike won't start moving until like 5000rpm, but as soon as it gets to 4 mph the clutch will catch and revs will drop to like 2000-3000rpm.
Am I doing something wrong here?
I tried to put stiffer springs into the starter clutch, but then it gets harder to push start it, like you can't start it by just pushing with your legs while on the bike. Haven't got pedals yeah.
Re: Making Peugeot take off at higher revs
Do you have a kit on it ?
Yes when the clutch grabs it drops the RPMs, but if you have enough power you can build up and overcome that lag. Try 2 balls and 2 star springs to get higher rev so you can get into the power you need.
Otherwise you need a clutch pulley.
Yes it's the polini 70cc and it's got power. What I'm saying is I don't see how modifying the main clutch (balls and star spring) helps to improve the takeoff, since the starter clutch (bell&pads) will still catch dead at very low speed and your rpms will drop.
I don't know either, but it works. My engine revs to about 4600 before it moves at all with 3balls/2 springs. If I lay on the throttle it will grab and take off decently while only dropping the RPMs to 3800'ish and the revs pick right back up, even uphill.
Stop worrying about the starter clutch. The starter clutch is moot once the motor starts. Its all about the main clutch and any component that has the "double D" hole that works directly 1:1 with the crankshaft
ie the clutch bell and the Centrifugal thrust plate.
The starter clutch might as well not exist at this point since you hopefully are not still pedaling the bike causing the arms to fly out and touch the sides of the clutch bell which at this point is spinning faster than you could ever pedal and the bell dosent even know the starter shoes are there,
Now its all about how much weight the centrifugal thrust plate can deliver to the pressure plate via the thrust balls, then the pressure plate to the disc
then the disc to the flat surface of the spinning bell.
The slower this happens the more slip you have and the higher the bike can rev. You want the clutch to slip.
If your bike starts that's all you need to think about as far as the starter clutch goes. Modifiying it would be like plugging off the holes in a salt shaker.
You might be two smart for the simpleness of mopeds, no disrespect intended but I have seen it before. (edited)
All the retardedness of starter clutch mods aside, I found some sort of weird vintage race clutch that fits a lot tighter in the housing than the stock clutch; seems to stall engagement another 500-1k with 2 balls. Looks similar to the tjt, but I can't say for sure.
HaHa, I Poo Poo the insinuation that such a part exists.
I think if you look where you last left it you will only find a pile of glitter.
What then will stay your enterwebs tongue?
Or tell us more please.
Cheetah, I love your advice usually, but here I think you're wrong. Just like on my hobbit, my peugeot starter clutches bog the motor as soon as I get to pedal starting speeds.
Yes you could be right there too. I often fell the strange shudder when pulling to a stop sign and wonder if the bike will die but then AAHHH then the smooth RPMs of total release, and I know I am safe till the next stop.
Or that nagging drone when the clutch seem to be not quite released and you know something is dragging so you start to bang on the variator with your left boot heel but you know the only way is to kill the bike and rock it back and forth.
Only when its hot though.
Yes but it gets into play again as soon as the bike starts rolling.
The speed (i.e. rear will rpms) of start clutch engaging will always be relatively low otherwise bike won't start.
The rpms at which main clutch engages and bike gets into movement may be as high as you like, but once the starter ctutch reaches speed at which bike normally starts, it will engage all the same and bog down the motor.
Yess that's it.
The golden solution seems to somehow prevent the starter clutch from engaging if the bell is rotating faster than the vario.
"Or that nagging drone when the clutch seem to be not quite released and you know something is dragging so you start to bang on the variator with your left boot heel but you know the only way is to kill the bike and rock it back and forth.
Only when its hot though."
Yes... This. I fucking hate this more than anything I have ever hated that is moped related. Motor gets hot and stuck. Won't even come unstuck after a few miles. I have went to 3 balls and 2 clutch springs, then to 3 clutch springs. The three springs kinda helped, but it made the clutch engage so high I hated it. It would just rev high as hell catch and bog some, then go.
I think that the heat in the clutch is causing the clutch springs to loose their tension? FUUUUCK, I need to just go clutched pulley and be done with it but that shit is expensive. Maybe I need to drill some holes in the clutch bell and cool this clutch down. Next time I'm in the shop I'll give it a shot and report back.
So what you are trying to get is your clutch to slip like it should so the bike can maintain the super high RPMs for forty or so feet till it ultimately must engage fully at 1:1 with the crank and bell?
But instead no matter what mods you do the balls and springs the starter shoes are engaging in ten feet forcing the clutch bell and crank to meet the variator in a 1;1 ratio for that pitiful "YEEEooommmp that we all try to avoid.
I think I understand now and sorry I totally missed what you were trying to convey.
Have you tried just leaving out the starter shoes and then starting with a belt or drill? That way you can put to rest the things you are feeling.
I think I will do some experiments on this today.
Some how some way.. get rid of the starter clutch shoes.
Pull start = DONE.
I'm with Charlie on the heat issue. I hate having to use 2 star springs, but I really really hate that damn locking clutch. Clutch pulley is not the real answer because it becomes on throttle or off throttle.
Yes Ed, I am finding out what you and most everyone else might already know. The starter shoes keep you from getting that long hi reving, clutch stinking, cock hardening take off from a stop,
I did some runs with my shoes out and It was a perfect launch with no bog down caused by the starters.
Did you think there would not be a tutorial? Have a seat.
Figured I would use my polini street runner that I ride 3 times a week for this experiment. Plus it had gas.
I remove the variator and shuck the parts out on the table. This setup has three balls and one star. the shoes came out really easy since I keep my stuff pretty well maintained.
Note to Charlie: see the little brass washer there? I got a pack of those from ACE hardware. It lays right under the beveled washer on top of the inner bearing race and plastic washer. helps with the binding. I think they are called sink valve shims.
Bolt it back together sans starter shoes. I am starting to take note that with no shoes all the torque will now be transfered through the skinny locking ring posts. I wonder if the ring will want to flex or distort with no shoes in there to back it up so to speak..
Slap the shit back on and figure out how to start it now.
If I try to start it by wrapping something on the flywheel I will definatly have to run with no top covers as they are in the way.
I tried using this dress belt but after about ten pulls I bloodied my lip and threw it out in the street.
I think If I had a leather strap 1/2 inch wide and 5 feet long This would work with one pull
Till then, Fuck all the dumb shit.
Got it running of course and yes yes yes. No bog or interference just a high rev, followed by a steady clutch slip for about 50 feet or so till the variator met the crank at 1:1
So instead of the variator bringing the crank speed down to it. The crank speed made the variator come up to meet it.
I see and feel more tuning opps that have opened up.
Funny thing though, as I was doing my last turnaround while test riding, I see something rolling out on the ground. It was my flywheel nut.
It must have broken loose when the drill kicked back when starting.
Stupidly I killed the bike and bent down to pick up the nut, then it dawned that I cant start the bike now. FUCK ME!!
I resign to start pushing the bike 1/2 mile home when I remember someone said you can kick the flywheel and start a bike.
A couple of practice kicks later and IT WORKED, HOORAY.
I rode back home and killed the bike, then tried the kicking again and now its easy.
I must consider that the bike is warm and this might not be so easy when cold. Although I could take the belt off for less resistance.
I will let the bike cool way down and let you guys know.
Better get a nut on there before you kick the flywheel off. Why not do the poorman's pullstart since you already have the Moby CDI on it ? Also it would probably be worth it to put a real pullstart or kickstart on there.
> it up so to speak..
That's what bothers me in "no starter pads" setup. That and the fact the clutch will disengage once below 3-4 Krpm, so no more easy rolling through traffic.
I am going to wait this one out. I love the idea of it and it sounds perfect, except for the whole "I kind of need to start my bike" thing.
Ha Ha I put it back on as soon as I picked it up but then didn't have a way to tighten it so I pocketed it
Hey! I'm the guy that laps all of his tapers. My shit don't move. But it did cross my mind when I was kicking it.
By the way I failed at cold starting the bike with kicks and had to do the drill.
I took the bike out and pounded the shit out of it and tried a couple different ball/star combos and settled on 3 balls two stars. But now I have the reoccuring bind up at stops.
I need to go with a thinner adjusting washer to cure this.
Aaron if you mean poor mans as in two bolts hanging out of the flywheel holes to wrap a rope in a figure 8. Too dangerous.
Can you put me onto a link for a real pullstart? That would be great.
I do have a real Peugeot kickstart crank from a SPX but I'm clueless as to what I would need to finnish it out.
^ SEXY !!!!
As for pull start:
This Pull Start is all metal with the throw out pawls so it should work although it is a little small. I think Tomahawk is making pull starts so maybe find that thread and... yeah you know.
Best part about it no more coming to a stop it acts like its shift .. waaaaa then disengagement happens.. Just smoothness. honda derbi pugs.. never mess with a moby nor a came to.. that one also. Speed limiters is what they are.. 30mph flat level ground.
Funny you should mention that Ed. I know what you mean and I thought it would not do that any more. but it does. I can approach a corner at about 30 and as I start the turn its like I just stepped on a gear shifter and threw it down one. I really got to grip the bars and if you not expecting it its scary.
I think it has to do with stacking my motor variation springs one inside the other with various lengths.
The only thing I miss about my stater clutches is engine braking from constant engagement while in motion. However that is offset by the worry that my bike is running at very high rpm while I come to a stop with little to no fuel flowing. That caused a constant and subconscious throttle blip that I still do even when moderately hard braking.
I need stiffer progressive spring sets like Cheetah. Have you ever ran a full length stock spring in Malossi cases ? I had to cut mine down to get full variation, but I guess I could stack inside it now that it fits and works.
mark, i went with a gas strut and the hell with the springs. really able to make it rev out hard. i thought about having some springs made and they did come in couple different lengths.
Okay, remove starter clutches, and buy a shim thing from ace. I'm trying to wrap my head around how it helps with binding, and what is actuality binding. I could have sworn in had it related to the heat caused by the clutch. dyno. I'm gonna give it a shot. Fab some sort of pull start. I'm on it.
A pullstart that could still keep the pedals and I would ditch my starter clutch too.
I HAVE HAD IT!!!! There is no use doing the No starter shoes mod and having this illicit affair with smooth take off power if I cant rely on my clutch not binding and stalling when it feels like it.
Its just too embarrassing to have to now push the bike off the road at a red light and start kicking at the flywheel like a crazy man while cagers stare at me with their fat foolish faces sucking at soda straws.
I'm going into my work room and make like Willy Wonka. I'm not coming back to MA till I fine a mod to correct this phenomenom.
Or Till I brew that cola that will let us all fly.
Cheetah, please help fix this horid problem. I have worked on this for a while to no avail! The best I have gotten is three star springs and it got better. Then it would stick again. Just takes longer to stick. It has to be the heat of the clutch disc transferring into the springs and losing tension? The added slippage would make more heat. If this is the case we need to concentrate on cooling the clutch. Holes in the bell and it would be lighter? I know they sell lightened ones on treats. Hmm...
