Re: Snowflake Disc Brake - DIY w/PICs
Ed - Dead Possums /
This is in the wiki. You can save the link there.
Helped me with this turd
And dual disks for this turd.
Charles Cole (OFMC) /
I'll bet that stops real nice!
It does. It was a pain in the ass to get everything lined up, but in the end it was worth it.
does that macho have a rear foot brake?!
Snap into a fucking AWESOME
Some close up pix would be nice.
I had a small build thread on the bike.
https://www.mopedarmy.com/forums/read.php?7,4186277,4189966,page=2#msg-4189966
The rear brake was a pain in the ass, but worth it in the end.
I’ll take a couple better ones when I pull the bike out later. (edited)
Nice!
Dirty30 Dillon /
I am building a grande-based bike that needed a front snowflake disk, so naturally I wanted to try this.
We able to find a 220mm rotor that fits the GM idler pulley perfectly. Now I have to just press everything together.
todd amundson /
Wheres that rotor from?
Dirty30 Dillon /
Whoops, I lied, it's 260~mm
https://www.ebay.com/itm/362147933690
todd amundson /
Thanks thought so. This is the biggest one iv'e found that has a small enough bolt circle for mounting. It's actually perfect. Don't tell anybody else.
That is a nice rotor! Hands down best mod to a moped. Something about being able to stop is awesome.
Dirty30 Dillon /
I was just gonna "get by" with snowflake drums, but I really want to be able to stop this grande/sacre project which will actually require brakes unlike most of my mopeds.
we gonna wiki this?
kevin Smellaflange /
the new guru...
there should be a special certificate... or a tax write off benny...or somethin'...great job
Ed - Dead Possums /
Thanks for all the support over the years!
I can now make custom aluminum hubs on my lathe so hit me up if you want to go that route!
Holy smokes!
Nice! What would one of them pieces set ya back.
Ed - Dead Possums /
$100
I can also provide complete or partial packages with disc($20), hardware($5-$10), drill/tap ($20-30) caliper/lever($45-$165 depending on what caliper/lever you want to use).
Shipping $10-15
todd amundson /
Garelli's stop before fluid even leaves the reservoir
Ed did mine. Highly recommend.
Looks great wowz !
Ok anyone here did this conversion to FA50 49cc ?
Read the thread.
If the brake hub is 90mm then you can do it
Dirty30 Dillon /
No, but probably because the stock FA50 forks have no area to mount a disk, and even if they did their design is highly prone to flex and therefore not ideal
