Re: Snowflake Disc Brake - DIY w/PICs
Neil Burgess /
Here's pics of this mod on my Hobbit mags with KX65 fork conversion-
I started out by buying a complete brake system for a GY6 50cc scooter GY6 scooter brake.
I bought a KX65 caliper to easily bolt onto my forks, and I also bought the GY6's rotor GY6 rotor. The rotor was advertised as a 180mm same as the KX65, yet measured 190mm. Once mounted and trued, I just spun the wheel/rotor and marked with a sharpie, then used a bench grinder to take off the excess. In actuality I didn't have to remove much, just a couple mm's so the rotor would clear the inside of the KX caliper. Don't mind the spacers on the caliper bolts, this was just for fit and I've replaced with new bolts of the proper length:
Luckily the GY6 line and abs unit bolted right into the KX caliper no problem. My rotor/pulley install had to be spaced out of the Hobbit mag about half way, but that saved me having to use spacers between the fork and caliper. There was still plenty of meat there to put in my set screws.
It all worked out good- now I have the disc brake with the GY6's ABS unit. I'm hoping that abs works so maybe I won't endo every time I hit the brakes lol, as some people have said the disc works too well vs. the old drum. I'll get to try them out in the next couple of days, I'm still getting the rest of my bike back together. Here it is with fender mounted(in my messy shop lmao, I've been cleaning in there too!)
(edited)
  Snowflake Disc Brake - DIY w/PICsTopic by: Ed - Dead Possums Ed - Dead Possums 06/21/13 02:32PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 06/21/13 02:35PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Old Greg Motorcityriot Old Greg Motorcityriot 06/22/13 12:32AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Rich (OFMC) Rich (OFMC) 06/21/13 02:36PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 06/21/13 02:52PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Dirty30 Dillon Dirty30 Dillon 06/21/13 02:42PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Noodles !!!! Noodles !!!! 07/02/15 02:39PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 07/04/15 11:06PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: ian van opijnen ian van opijnen 06/21/13 03:20PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ryan Graeme Ryan Graeme 06/21/13 03:28PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: OGvandal MPG OGvandal MPG 06/21/13 03:39PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: _ olazy _ olazy 06/21/13 03:52PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 06/21/13 03:58PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Bobby Sims Bobby Sims 06/21/13 08:51PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Adam Klags MPG Adam Klags MPG 06/21/13 09:23PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 06/21/13 10:09PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 06/21/13 09:15PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Probably Fred Probably Fred 06/21/13 09:25PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 06/21/13 09:32PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Josh Cranston Josh Cranston 06/21/13 10:26PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Josh Cranston Josh Cranston 06/21/13 10:45PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Magnus Burkal Magnus Burkal 06/22/13 05:28AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ryan Graeme Ryan Graeme 06/22/13 07:16AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 06/22/13 11:50AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Jax Rhapsody Jax Rhapsody 08/03/13 12:03AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: *.* HONDA *.* HONDA 06/23/13 02:54AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/23/13 03:21AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: *.* HONDA *.* HONDA 06/23/13 05:05AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Road Rash Dave Road Rash Dave 06/23/13 09:14AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Josh Cranston Josh Cranston 06/23/13 09:28AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 06/23/13 09:41AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Rachid Z Rachid Z 06/23/13 10:54AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 06/23/13 11:13PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: † CH∆D † † CH∆D † 06/24/13 09:56AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 06/24/13 10:54AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: MPB Andyrew MPB Andyrew 06/24/13 11:13AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Michael Evans Michael Evans 06/24/13 02:03PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 06/24/13 02:08PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Michael Evans Michael Evans 06/24/13 02:11PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Big Al's Moped Shop Big Al's Moped Shop 06/24/13 03:37PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Dan O Dan O 06/24/13 09:02PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Probably Fred Probably Fred 06/26/13 07:01AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 06/27/13 05:46PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Graham Motzing Graham Motzing 07/26/13 12:59PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Aron Chaudiere Aron Chaudiere 06/26/13 01:45AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Dan O Dan O 06/26/13 08:15AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Deadped Ryan Deadped Ryan 06/28/13 06:47PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Troy Rank Troy Rank 07/11/13 01:09PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Neil Burgess Neil Burgess 07/26/13 11:38AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: grim ripper grim ripper 07/26/13 01:56PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Gromosaurus Rex - Brad Pitt Gromosaurus Rex - Brad Pitt 07/26/13 05:05PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 07/26/13 06:08PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Jared Dobbs Jared Dobbs 07/26/13 08:19PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: NoISy BOyS JoHN NoISy BOyS JoHN 07/28/13 09:54PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 08/02/13 01:12PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Owen Walker Owen Walker 08/03/13 08:49AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Neil Burgess Neil Burgess 08/05/13 09:54AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Deadbolt Don Deadbolt Don 08/06/13 09:09AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Graham Motzing Graham Motzing 08/06/13 09:12AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Deadbolt Don Deadbolt Don 08/06/13 10:03AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Neil Burgess Neil Burgess 08/06/13 11:36PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 08/02/13 03:03PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Neil Burgess Neil Burgess 08/05/13 09:30AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Adam Klags MPG Adam Klags MPG 10/16/13 04:19PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 10/16/13 04:27PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Adam Klags MPG Adam Klags MPG 10/16/13 04:33PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Maciek Dub Maciek Dub 10/16/13 06:46PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ty 🏍 Ty 🏍 11/24/13 10:20PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ty 🏍 Ty 🏍 11/24/13 10:23PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Deadped Ryan Deadped Ryan 11/24/13 10:37PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ryan P Ryan P 11/26/13 07:17AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 11/26/13 07:39AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Eero W Eero W 11/26/13 11:42PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 11/26/13 11:49PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: river 2strokes river 2strokes 11/30/13 01:57PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 11/30/13 02:17PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Eero W Eero W 12/01/13 12:39AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: paul massey paul massey 12/01/13 06:55PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 12/01/13 07:32PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Eero W Eero W 12/01/13 08:02PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 12/01/13 08:08PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Eero W Eero W 12/05/13 11:21PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/06/13 02:29PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Eero W Eero W 12/08/13 12:04PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/08/13 12:46PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Eero W Eero W 12/08/13 01:12PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/08/13 01:17PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 12/08/13 01:17PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Eero W Eero W 12/08/13 02:37PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/08/13 04:12PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: jaime diaz jaime diaz 12/09/13 12:04AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M∆®†Y Køk€š M∆®†Y Køk€š 12/18/13 12:00PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M∆®†Y Køk€š M∆®†Y Køk€š 12/09/13 12:17AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Eero W Eero W 12/09/13 01:58AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M∆®†Y Køk€š M∆®†Y Køk€š 12/09/13 11:50AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Eero W Eero W 12/09/13 07:38PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/09/13 07:48PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/12/13 10:32PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M∆®†Y Køk€š M∆®†Y Køk€š 12/18/13 11:54AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/19/13 12:45AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M∆®†Y Køk€š M∆®†Y Køk€š 12/19/13 10:30AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Charlie BUZZARD Charlie BUZZARD 12/18/13 11:35PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/19/13 08:09PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 12/20/13 10:28PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/23/13 10:10PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 12/23/13 11:15PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/24/13 12:02AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: MTech -> MTech -> 12/24/13 07:54PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/25/13 05:04PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/27/13 09:55AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/29/13 09:53PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 12/29/13 11:16PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 12/30/13 06:22AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: † CH∆D † † CH∆D † 12/30/13 12:28AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Charles Cole (OFMC) Charles Cole (OFMC) 12/30/13 02:20AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M∆®†Y Køk€š M∆®†Y Køk€š 12/30/13 10:13AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 01/02/14 10:58AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 02/10/14 03:58PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 02/21/14 12:35PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: .♠.MSG .♠. .♠.MSG .♠. 05/28/15 10:55AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 05/28/15 11:04AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Chris K Chris K 06/17/15 08:19PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Born to be WillD Born to be WillD 02/21/14 02:23PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 02/24/14 07:42PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Adam Klags MPG Adam Klags MPG 02/25/14 12:24PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 02/25/14 12:55PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Yung Spil Yung Spil 07/06/15 09:09PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Adam Klags MPG Adam Klags MPG 02/25/14 01:48PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 02/25/14 02:30PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Derf Burg Derf Burg 02/25/14 02:56PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 02/25/14 03:14PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Derf Burg Derf Burg 02/25/14 03:36PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 02/25/14 03:42PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M∆®†Y Køk€š M∆®†Y Køk€š 02/26/14 10:24AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: «tyler » «tyler » 04/25/14 01:23PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Andy Paris Andy Paris 04/25/14 01:30PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: «tyler » «tyler » 04/25/14 02:17PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: «tyler » «tyler » 04/26/14 10:25AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: «tyler » «tyler » 04/26/14 10:28AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: T y l e r T y l e r 10/03/14 10:14PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Andy Paris Andy Paris 04/26/14 06:01PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 04/26/14 06:45PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Andy Paris Andy Paris 04/27/14 04:12AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 04/28/14 07:27PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Andy Paris Andy Paris 04/29/14 06:30AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Walt W Walt W 05/09/14 08:59PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 05/09/14 11:09PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Rachid Z Rachid Z 06/28/14 09:20AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 06/28/14 09:45AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Rachid Z Rachid Z 06/28/14 09:59AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 06/28/14 10:01AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Josiah McCoy Josiah McCoy 06/28/14 07:02PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 06/28/14 08:43PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M-Tenn Aaron M-Tenn Aaron 07/30/14 11:26PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 07/30/14 11:35PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: TRES RAYOS. ADAM S. TRES RAYOS. ADAM S. 08/14/14 06:55PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: John Moore John Moore 08/28/14 12:40PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: M∆®†Y Køk€š M∆®†Y Køk€š 09/28/14 02:51AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: MPB Andyrew MPB Andyrew 06/17/15 02:52PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Maciek Dub Maciek Dub 06/17/15 07:36PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: MPB Andyrew MPB Andyrew 06/18/15 08:07AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Dave & Bummerzz Dave & Bummerzz 06/18/15 09:42AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: MPB Andyrew MPB Andyrew 06/18/15 10:20AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: MPB Andyrew MPB Andyrew 07/06/15 09:39AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Thomas TPRF Thomas TPRF 07/06/15 10:17AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: peter heid peter heid 07/06/15 05:48PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: MPB Andyrew MPB Andyrew 07/06/15 10:26PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Moped "And you will know him by the trail of dead" Mime Moped "And you will know him by the trail of dead" Mime 08/21/15 02:35PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: .♠.MSG .♠. .♠.MSG .♠. 08/26/15 01:40AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Dave & Bummerzz Dave & Bummerzz 08/26/15 10:31AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: cheetahchrome . cheetahchrome . 01/08/16 09:35AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: todd amundson todd amundson 01/08/16 10:03AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: cheetahchrome . cheetahchrome . 01/08/16 10:41AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Eric P Eric P 03/01/16 01:22PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 03/01/16 06:51PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Wild West Pony Wild West Pony 03/02/16 04:14PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Kim Jong illest Kim Jong illest 07/01/16 06:32AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 07/01/16 07:00AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Judd Bagladi Judd Bagladi 07/01/16 03:52PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Clay Colburn Clay Colburn 07/03/16 07:53PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: .♠.MSG .♠. .♠.MSG .♠. 07/04/16 12:43PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Bob Brockett Bob Brockett 07/07/16 06:41PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 07/08/16 07:47AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 07/08/16 07:49AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Travis Noll Travis Noll 07/08/16 10:37AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: cheetahchrome . cheetahchrome . 07/08/16 11:28AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Lee S Lee S 02/17/17 08:47PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Tim brown Tim brown 02/23/17 01:39PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Mike Boyd Mike Boyd 02/23/17 02:10PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Tim brown Tim brown 02/24/17 09:00PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Siezed Again Siezed Again 02/25/17 09:46AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Tim brown Tim brown 02/25/17 10:14AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Tim brown Tim brown 06/22/17 10:42AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ryan Graeme Ryan Graeme 06/22/17 04:06PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 06/22/17 06:45PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Neil Verchot Neil Verchot 01/03/18 10:21PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 01/03/18 10:26PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Neil Verchot Neil Verchot 01/03/18 10:32PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Siezed Again Siezed Again 02/25/17 09:48AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 02/14/18 11:07PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Sam D Sam D 02/16/18 11:57AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Thomas TPRF Thomas TPRF 02/18/18 01:04PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Dave & Bummerzz Dave & Bummerzz 02/19/18 09:02AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Derek Cox Derek Cox 02/19/18 09:41AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 04/23/18 10:42PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 04/23/18 11:02PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/24/18 12:36PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Eric Bloomquist Eric Bloomquist 04/25/18 10:31PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Charles Cole (OFMC) Charles Cole (OFMC) 04/26/18 01:02AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/26/18 06:29AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Charles Cole (OFMC) Charles Cole (OFMC) 04/24/18 10:06PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/24/18 10:39PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Steve Paul Steve Paul 04/28/18 09:28AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Dirty30 Dillon Dirty30 Dillon 02/19/19 09:42AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 02/19/19 11:59AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Dirty30 Dillon Dirty30 Dillon 02/19/19 12:14PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: todd amundson todd amundson 02/19/19 10:40AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Dirty30 Dillon Dirty30 Dillon 02/19/19 10:59AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: todd amundson todd amundson 02/19/19 11:05AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: mit mortso mit mortso 02/20/19 07:40PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: kevin Smellaflange kevin Smellaflange 02/21/19 09:51AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 01/12/20 12:54AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ryan Graeme Ryan Graeme 01/12/20 04:42AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/12/20 11:30AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ed - Dead Possums Ed - Dead Possums 01/12/20 12:19PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: todd amundson todd amundson 01/12/20 01:04PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Ike Pipe Ike Pipe 01/13/20 11:36PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: scrot rash scrot rash 01/18/20 11:31PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Andy Le Andy Le 09/29/21 12:31PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: * wormdirt * * wormdirt * 09/29/21 08:55PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Dirty30 Dillon Dirty30 Dillon 09/30/21 12:53PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Salsa Salsa Salsa Salsa 07/26/13 02:14PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: CORN PED CORN PED 12/18/13 12:19PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: Eero W Eero W 01/03/14 11:45AM
  Re: Snowflake Disc Brake - DIY w/PICsRe: «tyler » «tyler » 06/28/14 10:44PM
  Re: Snowflake Disc Brake - DIY w/PICsRe: James Peterson James Peterson 05/12/16 06:44AM
