Which athena kit do i have?
john cervini /
So i just got a 79 puch maxi sport mkII. I can see athena on the cylinder underneath. There are some other numbers on there as well. It has a 15mm bing, 14mm intake and a bi turbo exhaust. Is there a way to determine what size kit i have? Thanks, John
Re: Which athena kit do i have?
take a picture. that will help us.
if it has the 14mm intake, its probably just the piston port 70cc athena. your doing great, though!
john cervini /
I will get pics in the morning. Thanks, it was nice not to have to drive too far for this one. I found it on cl about an hour after it posted. I found the transferable registration taped under the seat. It has nice clean snowflakes also.
john cervini /
john cervini /
john cervini /
So i have started looking into this. It has the 15mm bing with a 2.17 atomizer and a 88 jet. Here are some pics of the cylinder and head.
Looks like a 70cc Athena and a high comp head.
john cervini /
Thank you!
Overpriced Parts /
Old style normal compression 70cc head
john cervini /
Thanks ken. What kind of performance should i expect with this setup?
Head gasket?
john cervini /
what about the head gasket?
Can't tell if it has one. If so, is it metal?
john cervini /
it has one but its not metal. It looks like rubber. I cleaned the carb, put fresh gas and she roared to life! There is something hinky about the throttle cable. There is no bend going into the carb just a straight fitting and it's loose. Also there is about 4 inches of extra cable after it goes through the throttle.
Then fix it.
And switch to a metal head gasket.
john cervini /
throttle is fixed. What is the benefit of a metal head gasket?
Better compression, no head leaks.
With everything tuned right you should be upper 40s, maybe 50.
john cervini /
ah ok makes sense. i am thinking of taking the za50 off this one and putting it on my magnum xk
