malossi/ducati voltage regulator wiring
Anyone know how to wire this voltage regulator?
https://www.treatland.tv/malossi-CDI-ducati-voltage-regulator-p/malossi-voltage-regulator.htm
I understand the ground, but should the other two connectors be wired in parallel to the wires from the stator? or is this an input/output wiring situation?
Any help would be much appreciated.
Re: malossi/ducati voltage regulator wiring
In/Out. Doesn't matter which one is in or out as long as the ground wire is the ground. They work great too. Good buy.
Thanks for the help dude! I'm glad I picked a good one.
I'm looking forward to saving time and money dollars on replacing bulbs.
Yeah you got the best one. It works with 6v and 12v. I use them on hard wire and just splice the head and tail to the one out. Never blow bulbs and keeps a decent amount of light at idle.
