Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kit
jordan * /
hey guys, doing some research. what's the technical term for the stacked transfer ports? googling that term didn't bring much info. what do these do? at bdc they wouldn't be letting more fresh charge into cylinder in the same manner as main transfers. just to help cool the piston or what is the advantage of these? i've seen them on a fair amount of french kits and also the puch autisa 47mm reed cylinder so it's not just a piston port thing. two stroke tuners handbook didn't mention them from what i can tell.
sorry for zombie thread, just interested in this kit + some porting knowledge.
  Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitTopic by: Private Ryan Private Ryan 01/14/13 03:31AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charlie BUZZARD Charlie BUZZARD 01/14/13 09:20AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 01/14/13 09:28AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: -Brian- The Ruffians STL -Brian- The Ruffians STL 01/14/13 10:49AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ◕ ‿ ◕ ◕ ‿ ◕ 01/14/13 11:16AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 01/14/13 11:22AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 01/14/13 11:24AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 01/14/13 11:44AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Private Ryan Private Ryan 01/14/13 11:45AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 01/14/13 12:15PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Torrin _ Torrin _ 01/14/13 03:41PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 01/14/13 04:17PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Torrin _ Torrin _ 01/14/13 05:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 01/14/13 04:28PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: J Blank J Blank 01/14/13 06:19PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: 🎨🏆 Duncan 🎨🏆 Duncan 01/15/13 12:32AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Born to be WillD Born to be WillD 01/15/13 11:29AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: - Summerai - Drew - Summerai - Drew 01/15/13 11:49AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 01/15/13 12:13PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Ryan N. Ryan N. 01/15/13 01:06PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ◕ ‿ ◕ ◕ ‿ ◕ 01/15/13 12:41PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Private Ryan Private Ryan 01/15/13 08:45PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 01/15/13 09:19PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charlie BUZZARD Charlie BUZZARD 01/16/13 10:41AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charlie BUZZARD Charlie BUZZARD 01/16/13 10:42AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Daniel '' Daniel '' 01/16/13 04:14PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charlie BUZZARD Charlie BUZZARD 01/16/13 04:19PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Private Ryan Private Ryan 01/16/13 11:50PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Jake P Jake P 01/17/13 02:00AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Private Ryan Private Ryan 01/16/13 11:54PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kees Maxi Kees Maxi 02/11/13 06:41PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 02/11/13 06:51PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kees Maxi Kees Maxi 02/11/13 07:02PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 02/11/13 07:07PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kees Maxi Kees Maxi 02/11/13 07:11PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 01/17/13 09:32AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Brian Scarborough Brian Scarborough 01/17/13 06:30PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: -Brian- The Ruffians STL -Brian- The Ruffians STL 01/17/13 07:44PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Adam Pereira Adam Pereira 02/05/13 10:01AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 02/05/13 01:52PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Tracy Meade Tracy Meade 02/05/13 02:16PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Pablo Puchasso Pablo Puchasso 02/05/13 03:46PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Tracy Meade Tracy Meade 02/05/13 04:03PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 02/11/13 07:33PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 02/11/13 07:42PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 02/11/13 08:23PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Chris HnRz Chris HnRz 03/19/13 09:20PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charlie BUZZARD Charlie BUZZARD 03/20/13 08:29AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kevin Bishop Kevin Bishop 03/20/13 09:17AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Rich (OFMC) Rich (OFMC) 04/14/13 08:09PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 04/14/13 09:43PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Rich (OFMC) Rich (OFMC) 04/15/13 07:45AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 04/15/13 09:18AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ◕ ‿ ◕ ◕ ‿ ◕ 04/16/13 04:36PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Rich (OFMC) Rich (OFMC) 04/17/13 07:32PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Derek Stahl Derek Stahl 04/18/13 09:17PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ian van opijnen ian van opijnen 04/19/13 12:46AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 04/19/13 12:58AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Pablo Puchasso Pablo Puchasso 04/19/13 04:17AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ◕ ‿ ◕ ◕ ‿ ◕ 04/19/13 07:40AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ian van opijnen ian van opijnen 04/19/13 02:20AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Pablo Puchasso Pablo Puchasso 04/19/13 07:55AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Rich (OFMC) Rich (OFMC) 04/19/13 08:09AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ◕ ‿ ◕ ◕ ‿ ◕ 04/19/13 09:29AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ian van opijnen ian van opijnen 05/19/13 05:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 05/19/13 08:29PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Rich (OFMC) Rich (OFMC) 05/21/13 09:25AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Road Rash Dave Road Rash Dave 09/16/13 07:18PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 09/16/13 08:59PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 09/16/13 09:33PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 09/17/13 06:57PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Road Rash Dave Road Rash Dave 09/18/13 04:51PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dirty30 Dillon Dirty30 Dillon 09/18/13 05:23PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ian van opijnen ian van opijnen 05/20/13 09:48PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Private Ryan Private Ryan 05/21/13 02:33PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Gromosaurus Rex - Brad Pitt Gromosaurus Rex - Brad Pitt 07/07/13 03:43PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Devin Haley Devin Haley 07/08/13 02:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: not a Baron Asshole not a Baron Asshole 07/09/13 06:18PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 07/10/13 11:33AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: not a Baron Asshole not a Baron Asshole 07/10/13 02:05PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dirty30 Dillon Dirty30 Dillon 09/03/13 08:59PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kevin Bishop Kevin Bishop 09/03/13 09:15PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dirty30 Dillon Dirty30 Dillon 09/03/13 09:32PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 09/03/13 10:01PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dirty30 Dillon Dirty30 Dillon 09/03/13 10:30PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Pat Kelleher Pat Kelleher 09/16/13 01:14PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dirty30 Dillon Dirty30 Dillon 09/16/13 04:56PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Max (ツ) Max (ツ) 10/16/13 03:05PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 10/17/13 01:41AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 10/17/13 01:43AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Rich Levangie Rich Levangie 10/17/13 07:15AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ian van opijnen ian van opijnen 10/19/13 09:53PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Max (ツ) Max (ツ) 10/31/13 02:41PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Born to be WillD Born to be WillD 11/05/13 03:00PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 11/05/13 03:12PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dirty30 Dillon Dirty30 Dillon 11/05/13 04:02PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dimitri K Dimitri K 11/04/13 08:03PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 11/05/13 02:37PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: campeona del mundo campeona del mundo 11/05/13 03:12PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 11/05/13 06:29PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Max Johnson Max Johnson 11/06/13 06:05PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: joe muncey joe muncey 12/10/14 12:05AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 11/06/13 06:24PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Bas Autowas Bas Autowas 11/29/14 01:46PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kevin Pierce Kevin Pierce 11/06/13 06:59PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 11/06/13 07:32PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Derek Vanasse Derek Vanasse 11/13/13 09:27PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: I Am I Am 11/27/14 02:13PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: I Am I Am 11/27/14 02:34PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Crusty Hopper Crusty Hopper 11/27/14 04:00PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: I Am I Am 11/28/14 12:28PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/28/14 02:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: I Am I Am 11/28/14 05:01PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/28/14 07:00PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: I Am I Am 11/28/14 08:44PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Lazy Pedaler Lazy Pedaler 11/28/14 08:14PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Ryan N. Ryan N. 11/28/14 08:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: I Am I Am 11/28/14 09:43PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kyle M. Kyle M. 11/29/14 01:18AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 11/29/14 12:24PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/29/14 01:24PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/29/14 01:49PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Bas Autowas Bas Autowas 11/29/14 01:54PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/29/14 02:00PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Daniel '' Daniel '' 11/29/14 02:21PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charles Cole (OFMC) Charles Cole (OFMC) 11/29/14 04:15PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/29/14 04:22PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charles Cole (OFMC) Charles Cole (OFMC) 11/29/14 05:45PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/29/14 06:20PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charles Cole (OFMC) Charles Cole (OFMC) 12/02/14 04:18AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charles Cole (OFMC) Charles Cole (OFMC) 11/29/15 11:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 02/07/16 11:21AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Benjamin LaPlante Benjamin LaPlante 11/30/15 12:41AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Bas Autowas Bas Autowas 11/30/15 10:53AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Benjamin LaPlante Benjamin LaPlante 02/06/16 10:44AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kevin Bishop Kevin Bishop 02/13/16 09:09PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Max Johnson Max Johnson 02/13/16 09:34PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Daniel '' Daniel '' 02/15/16 06:05AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: MPB Andyrew MPB Andyrew 02/15/16 03:19PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kyle M. Kyle M. 02/15/16 03:47PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Cole Doubt Cole Doubt 02/17/16 06:33PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: campeona del mundo campeona del mundo 02/17/16 09:04PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Daniel '' Daniel '' 02/18/16 02:17AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: jordan * jordan * 06/03/16 09:00PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: James Peterson James Peterson 06/08/16 07:08PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/29/17 12:15PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Daniel '' Daniel '' 10/29/17 09:50PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/30/17 07:35PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 10/29/17 09:26PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Eduardo T Eduardo T 07/28/22 09:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Garelli Master✨ Garelli Master✨ 07/30/22 08:10AM
