Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kit
Brian Scarborough /
do you get alot of blow back out of the carb with this setup ?
i am using the 46mm airsal kit and before i had problems with gas getting spit out on my shoe and pant leg pretty badly.
i see there is a nice looking velocity stack on the carb - does it cure the gas spit out of the carb ?
  Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitTopic by: Private Ryan Private Ryan 01/14/13 03:31AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charlie BUZZARD Charlie BUZZARD 01/14/13 09:20AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 01/14/13 09:28AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: -Brian- The Ruffians STL -Brian- The Ruffians STL 01/14/13 10:49AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ◕ ‿ ◕ ◕ ‿ ◕ 01/14/13 11:16AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 01/14/13 11:22AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 01/14/13 11:24AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 01/14/13 11:44AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Private Ryan Private Ryan 01/14/13 11:45AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 01/14/13 12:15PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Torrin _ Torrin _ 01/14/13 03:41PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 01/14/13 04:17PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Torrin _ Torrin _ 01/14/13 05:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 01/14/13 04:28PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: J Blank J Blank 01/14/13 06:19PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: 🎨🏆 Duncan 🎨🏆 Duncan 01/15/13 12:32AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Born to be WillD Born to be WillD 01/15/13 11:29AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: - Summerai - Drew - Summerai - Drew 01/15/13 11:49AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 01/15/13 12:13PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Ryan N. Ryan N. 01/15/13 01:06PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ◕ ‿ ◕ ◕ ‿ ◕ 01/15/13 12:41PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Private Ryan Private Ryan 01/15/13 08:45PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 01/15/13 09:19PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charlie BUZZARD Charlie BUZZARD 01/16/13 10:41AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charlie BUZZARD Charlie BUZZARD 01/16/13 10:42AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Daniel '' Daniel '' 01/16/13 04:14PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charlie BUZZARD Charlie BUZZARD 01/16/13 04:19PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Private Ryan Private Ryan 01/16/13 11:50PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Jake P Jake P 01/17/13 02:00AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Private Ryan Private Ryan 01/16/13 11:54PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kees Maxi Kees Maxi 02/11/13 06:41PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 02/11/13 06:51PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kees Maxi Kees Maxi 02/11/13 07:02PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 02/11/13 07:07PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kees Maxi Kees Maxi 02/11/13 07:11PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 01/17/13 09:32AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Brian Scarborough Brian Scarborough 01/17/13 06:30PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: -Brian- The Ruffians STL -Brian- The Ruffians STL 01/17/13 07:44PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Adam Pereira Adam Pereira 02/05/13 10:01AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 02/05/13 01:52PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Tracy Meade Tracy Meade 02/05/13 02:16PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Pablo Puchasso Pablo Puchasso 02/05/13 03:46PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Tracy Meade Tracy Meade 02/05/13 04:03PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 02/11/13 07:33PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 02/11/13 07:42PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 02/11/13 08:23PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Chris HnRz Chris HnRz 03/19/13 09:20PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charlie BUZZARD Charlie BUZZARD 03/20/13 08:29AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kevin Bishop Kevin Bishop 03/20/13 09:17AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Rich (OFMC) Rich (OFMC) 04/14/13 08:09PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 04/14/13 09:43PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Rich (OFMC) Rich (OFMC) 04/15/13 07:45AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 04/15/13 09:18AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ◕ ‿ ◕ ◕ ‿ ◕ 04/16/13 04:36PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Rich (OFMC) Rich (OFMC) 04/17/13 07:32PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Derek Stahl Derek Stahl 04/18/13 09:17PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ian van opijnen ian van opijnen 04/19/13 12:46AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 04/19/13 12:58AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Pablo Puchasso Pablo Puchasso 04/19/13 04:17AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ◕ ‿ ◕ ◕ ‿ ◕ 04/19/13 07:40AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ian van opijnen ian van opijnen 04/19/13 02:20AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Pablo Puchasso Pablo Puchasso 04/19/13 07:55AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Rich (OFMC) Rich (OFMC) 04/19/13 08:09AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ◕ ‿ ◕ ◕ ‿ ◕ 04/19/13 09:29AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ian van opijnen ian van opijnen 05/19/13 05:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 05/19/13 08:29PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Rich (OFMC) Rich (OFMC) 05/21/13 09:25AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Road Rash Dave Road Rash Dave 09/16/13 07:18PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 09/16/13 08:59PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 09/16/13 09:33PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 09/17/13 06:57PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Road Rash Dave Road Rash Dave 09/18/13 04:51PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dirty30 Dillon Dirty30 Dillon 09/18/13 05:23PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ian van opijnen ian van opijnen 05/20/13 09:48PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Private Ryan Private Ryan 05/21/13 02:33PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Gromosaurus Rex - Brad Pitt Gromosaurus Rex - Brad Pitt 07/07/13 03:43PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Devin Haley Devin Haley 07/08/13 02:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: not a Baron Asshole not a Baron Asshole 07/09/13 06:18PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 07/10/13 11:33AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: not a Baron Asshole not a Baron Asshole 07/10/13 02:05PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dirty30 Dillon Dirty30 Dillon 09/03/13 08:59PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kevin Bishop Kevin Bishop 09/03/13 09:15PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dirty30 Dillon Dirty30 Dillon 09/03/13 09:32PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 09/03/13 10:01PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dirty30 Dillon Dirty30 Dillon 09/03/13 10:30PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Pat Kelleher Pat Kelleher 09/16/13 01:14PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dirty30 Dillon Dirty30 Dillon 09/16/13 04:56PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Max (ツ) Max (ツ) 10/16/13 03:05PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 10/17/13 01:41AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 10/17/13 01:43AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Rich Levangie Rich Levangie 10/17/13 07:15AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: ian van opijnen ian van opijnen 10/19/13 09:53PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Max (ツ) Max (ツ) 10/31/13 02:41PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Born to be WillD Born to be WillD 11/05/13 03:00PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: LSLB RXb LSLB RXb 11/05/13 03:12PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dirty30 Dillon Dirty30 Dillon 11/05/13 04:02PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Dimitri K Dimitri K 11/04/13 08:03PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 11/05/13 02:37PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: campeona del mundo campeona del mundo 11/05/13 03:12PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 11/05/13 06:29PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Max Johnson Max Johnson 11/06/13 06:05PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: joe muncey joe muncey 12/10/14 12:05AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 11/06/13 06:24PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Bas Autowas Bas Autowas 11/29/14 01:46PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kevin Pierce Kevin Pierce 11/06/13 06:59PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Totally normal JBOT Totally normal JBOT 11/06/13 07:32PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Derek Vanasse Derek Vanasse 11/13/13 09:27PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: I Am I Am 11/27/14 02:13PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: I Am I Am 11/27/14 02:34PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Crusty Hopper Crusty Hopper 11/27/14 04:00PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: I Am I Am 11/28/14 12:28PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/28/14 02:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: I Am I Am 11/28/14 05:01PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/28/14 07:00PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: I Am I Am 11/28/14 08:44PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Lazy Pedaler Lazy Pedaler 11/28/14 08:14PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Ryan N. Ryan N. 11/28/14 08:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: I Am I Am 11/28/14 09:43PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kyle M. Kyle M. 11/29/14 01:18AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 11/29/14 12:24PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/29/14 01:24PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/29/14 01:49PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Bas Autowas Bas Autowas 11/29/14 01:54PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/29/14 02:00PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Daniel '' Daniel '' 11/29/14 02:21PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charles Cole (OFMC) Charles Cole (OFMC) 11/29/14 04:15PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/29/14 04:22PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charles Cole (OFMC) Charles Cole (OFMC) 11/29/14 05:45PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Probably Fred Probably Fred 11/29/14 06:20PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charles Cole (OFMC) Charles Cole (OFMC) 12/02/14 04:18AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Charles Cole (OFMC) Charles Cole (OFMC) 11/29/15 11:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 02/07/16 11:21AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Benjamin LaPlante Benjamin LaPlante 11/30/15 12:41AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Bas Autowas Bas Autowas 11/30/15 10:53AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Benjamin LaPlante Benjamin LaPlante 02/06/16 10:44AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kevin Bishop Kevin Bishop 02/13/16 09:09PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Max Johnson Max Johnson 02/13/16 09:34PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Daniel '' Daniel '' 02/15/16 06:05AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: MPB Andyrew MPB Andyrew 02/15/16 03:19PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Kyle M. Kyle M. 02/15/16 03:47PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Cole Doubt Cole Doubt 02/17/16 06:33PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: campeona del mundo campeona del mundo 02/17/16 09:04PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Daniel '' Daniel '' 02/18/16 02:17AM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: jordan * jordan * 06/03/16 09:00PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: James Peterson James Peterson 06/08/16 07:08PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/29/17 12:15PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Daniel '' Daniel '' 10/29/17 09:50PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 10/30/17 07:35PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: will warn will warn 10/29/17 09:26PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Eduardo T Eduardo T 07/28/22 09:55PM
  Re: Test & Tune: Puch Airsal EUROKIT 47mm 6 port kitRe: Garelli Master✨ Garelli Master✨ 07/30/22 08:10AM
