Re: Arduino Based CDI
Graham Motzing /
yeah i've written some code... i've actually got two blinky lights working right now out of phase... which is a tremendous achievement from the code perspective because i've managed to manipulate one timer and use it to turn on/off the LED using output compare interrupts, so it runs completely in the background while my code executes.
i think if downloading the IDE, changing a hard-coded array, and re-burning the arduino is too 'advanced' people should probably not be fucking with this.... either make it canned without a USB interface.. pro Mini or whatever, or build the hardware as a shield and let anyone do whatever they want with it.
i ordered the LM1815's and some VND7N04's for the output, and i built a little 555 timer circuit to simulate the CDI output waveform, so i can adjust potentiometers and watch my program calculate RPM and blink an LED to simulate 'firing' the cdi.
all of that will happen in the background while the main program looks at variables, can run a display, and can program the OCR's to determine dwell and firing angle.
  Arduino Based CDITopic by: Mars   Mars   10/26/12 03:41PM
  Re: Arduino Based CDIRe: Josh G Josh G 10/26/12 03:48PM
  Re: Arduino Based CDIRe: Mars   Mars   10/26/12 03:55PM
  Re: Arduino Based CDIRe: Mars   Mars   10/26/12 04:06PM
  Re: Arduino Based CDIRe: Nele Sudar Nele Sudar 10/26/12 04:17PM
  Re: Arduino Based CDIRe: Thenggregy Cawilan Thenggregy Cawilan 08/06/20 06:45PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/07/20 07:18AM
  Re: Arduino Based CDIRe: Cooper Hennick Cooper Hennick 10/26/12 05:54PM
  Re: Arduino Based CDIRe: Jake Beckman Jake Beckman 10/26/12 06:44PM
  Re: Arduino Based CDIRe: M-Tenn Aaron M-Tenn Aaron 10/26/12 07:00PM
  Re: Arduino Based CDIRe: Nele Sudar Nele Sudar 10/26/12 07:40PM
  Re: Arduino Based CDIRe: Jason Collier Jason Collier 10/27/12 12:26AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 10/27/12 12:46PM
  Re: Arduino Based CDIRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 10/29/12 12:43AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 10/27/12 02:40PM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 10/27/12 06:24PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 10/27/12 03:26PM
  Re: Arduino Based CDIRe: Mars   Mars   10/27/12 03:35PM
  Re: Arduino Based CDIRe: NB0tt aholetechbro NB0tt aholetechbro 10/27/12 03:41PM
  Re: Arduino Based CDIRe: Mars   Mars   10/27/12 03:49PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 10/27/12 06:36PM
  Re: Arduino Based CDIRe: will warn will warn 10/27/12 08:31PM
  Re: Arduino Based CDIRe: Adam Russell Adam Russell 10/28/12 08:38AM
  Re: Arduino Based CDIRe: Adam Russell Adam Russell 10/28/12 09:10AM
  Re: Arduino Based CDIRe: Mars   Mars   10/28/12 06:56PM
  Re: Arduino Based CDIRe: Mars   Mars   10/28/12 11:50PM
  Re: Arduino Based CDIRe: 1 1 1 1 10/28/12 11:44PM
  Re: Arduino Based CDIRe: Chris B Chris B 10/29/12 10:02AM
  Re: Arduino Based CDIRe: Mars   Mars   10/29/12 10:44AM
  Re: Arduino Based CDIRe: Paul Dehmer Paul Dehmer 10/29/12 08:45PM
  Re: Arduino Based CDIRe: Time Warner Time Warner 10/31/12 07:43PM
  Re: Arduino Based CDIRe: Cooper Hennick Cooper Hennick 11/01/12 11:14AM
  Re: Arduino Based CDIRe: Mars   Mars   11/02/12 12:55AM
  Re: Arduino Based CDIRe: Sickster 6 Sickster 6 11/02/12 01:42PM
  Re: Arduino Based CDIRe: Mars   Mars   11/02/12 01:52PM
  Re: Arduino Based CDIRe: Dill . Dill . 11/03/12 01:12PM
  Re: Arduino Based CDIRe: Time Warner Time Warner 11/02/12 07:57PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/03/12 02:07PM
  Re: Arduino Based CDIRe: Dill . Dill . 11/06/12 09:46AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 11/06/12 09:50AM
  Re: Arduino Based CDIRe: Mars   Mars   11/06/12 10:29AM
  Re: Arduino Based CDIRe: Peter Fondue Peter Fondue 11/06/12 01:52PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 11/14/12 10:27AM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 11/20/12 01:57AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/20/12 09:36AM
  Re: Arduino Based CDIRe: Alejandro Schröeder Alejandro Schröeder 11/21/12 07:19PM
  Re: Arduino Based CDIRe: Mars   Mars   11/22/12 10:53AM
  Re: Arduino Based CDIRe: *.* HONDA *.* HONDA 11/22/12 08:44PM
  Re: Arduino Based CDIRe: Dill . Dill . 11/22/12 01:12PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 11/24/12 02:44AM
  Re: Arduino Based CDIRe: Mars   Mars   11/30/12 11:22PM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 12/14/12 12:18AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 12/14/12 12:35AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 12/14/12 09:05AM
  Re: Arduino Based CDIRe: Mars   Mars   12/14/12 09:54AM
  Re: Arduino Based CDIRe: The Blisster The Blisster 12/14/12 01:08PM
  Re: Arduino Based CDIRe: Mars   Mars   12/16/12 12:44AM
  Re: Arduino Based CDIRe: 1 1 1 1 12/16/12 12:50AM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 12/16/12 02:06AM
  Re: Arduino Based CDIRe: Mars   Mars   12/16/12 02:26PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 12/16/12 03:28PM
  Re: Arduino Based CDIRe: Mars   Mars   12/16/12 04:23PM
  Re: Arduino Based CDIRe: peter heid peter heid 11/16/14 07:52AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 12/16/12 04:49PM
  Re: Arduino Based CDIRe: Mars   Mars   12/16/12 05:21PM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 12/16/12 06:00PM
  Re: Arduino Based CDIRe: Ryan Mayer Ryan Mayer 12/16/12 09:11PM
  Re: Arduino Based CDIRe: SABAT! andDestroy SABAT! andDestroy 12/16/12 11:27PM
  Re: Arduino Based CDIRe: Mars   Mars   12/16/12 11:34PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 12/17/12 12:25AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 12/17/12 12:51AM
  Re: Arduino Based CDIRe: The Blisster The Blisster 12/18/12 02:15PM
  Re: Arduino Based CDIRe: Mars   Mars   12/18/12 02:22PM
  Re: Arduino Based CDIRe: Ryan Mayer Ryan Mayer 01/15/13 06:38AM
  Re: Arduino Based CDIRe: Mars   Mars   01/15/13 09:19AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 01/15/13 11:37AM
  Re: Arduino Based CDIRe: SABAT! andDestroy SABAT! andDestroy 01/15/13 11:30AM
  Re: Arduino Based CDIRe: Mars   Mars   01/15/13 11:54AM
  Re: Arduino Based CDIRe: Ryan Mayer Ryan Mayer 01/15/13 12:25PM
  Re: Arduino Based CDIRe: Ryan Mayer Ryan Mayer 01/15/13 12:41PM
  Re: Arduino Based CDIRe: Time Warner Time Warner 01/15/13 07:05PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 01/16/13 04:15PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 01/22/13 02:44AM
  Re: Arduino Based CDIRe: Time Warner Time Warner 01/23/13 01:21PM
  Re: Arduino Based CDIRe: Mars   Mars   01/23/13 01:29PM
  Re: Arduino Based CDIRe: Ryan Mayer Ryan Mayer 01/23/13 02:09PM
  Re: Arduino Based CDIRe: Mars   Mars   01/23/13 02:57PM
  Re: Arduino Based CDIRe: Emerica   Emerica   01/23/13 08:29PM
  Re: Arduino Based CDIRe: Mars   Mars   01/23/13 08:40PM
  Re: Arduino Based CDIRe: Emerica   Emerica   01/23/13 09:04PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 01/23/13 11:16PM
  Re: Arduino Based CDIRe: Mars   Mars   01/23/13 11:28PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 01/24/13 01:21AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/14/14 11:24AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/14/14 11:37AM
  Re: Arduino Based CDIRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/15/14 12:37PM
  Re: Arduino Based CDIRe: Thenggregy Cawilan Thenggregy Cawilan 08/13/20 12:50AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/14/14 12:42PM
  Re: Arduino Based CDIRe: Julie the Wizard Julie the Wizard 11/15/14 02:11AM
  Re: Arduino Based CDIRe: simon zarka simon zarka 11/15/14 05:10AM
  Re: Arduino Based CDIRe: Mars   Mars   11/15/14 09:34AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/15/14 04:47PM
  Re: Arduino Based CDIRe: «tyler » «tyler » 11/15/14 11:11PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/15/14 11:21PM
  Re: Arduino Based CDIRe: Mars   Mars   11/15/14 11:56PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/16/14 12:02AM
  Re: Arduino Based CDIRe: Mars   Mars   11/16/14 12:11AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/16/14 06:35AM
  Re: Arduino Based CDIRe: Thenggregy Cawilan Thenggregy Cawilan 08/13/20 12:45AM
  Re: Arduino Based CDIRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/16/14 08:28AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/16/14 02:15PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/16/14 02:19PM
  Re: Arduino Based CDIRe: Mars   Mars   11/16/14 10:24PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/17/14 12:18AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 11:31AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 11:36AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 11:38AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/16/14 03:22PM
  Re: Arduino Based CDIRe: Cody H Cody H 11/17/14 12:34PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 12:40PM
  Re: Arduino Based CDIRe: Cody H Cody H 11/17/14 12:48PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 12:55PM
  Re: Arduino Based CDIRe: Cody H Cody H 11/17/14 01:00PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 01:09PM
  Re: Arduino Based CDIRe: Cody H Cody H 11/17/14 01:52PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 01:59PM
  Re: Arduino Based CDIRe: Cody H Cody H 11/17/14 02:15PM
  Re: Arduino Based CDIRe: Mars   Mars   11/21/14 09:10AM
  Re: Arduino Based CDIRe: peter heid peter heid 11/22/14 01:28PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/21/14 01:35PM
  Re: Arduino Based CDIRe: Mars   Mars   11/21/14 02:14PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/21/14 03:51PM
  Re: Arduino Based CDIRe: Mars   Mars   11/21/14 04:16PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/21/14 06:18PM
  Re: Arduino Based CDIRe: «tyler » «tyler » 11/24/14 09:07AM
  Re: Arduino Based CDIRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/23/14 06:47AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/24/14 10:04AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/25/14 11:28AM
  Re: Arduino Based CDIRe: Mike Boyd Mike Boyd 03/04/16 04:17PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 03/11/16 12:52PM
  Re: Arduino Based CDIRe: Andres Pioli Andres Pioli 01/25/18 07:48PM
  Re: Arduino Based CDIRe: Mikey Antonakakis Mikey Antonakakis 01/25/18 10:41PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 01/26/18 10:42AM
  Re: Arduino Based CDIRe: Mikey Antonakakis Mikey Antonakakis 01/26/18 06:05PM
  Re: Arduino Based CDIRe: Lee Hoffguy Lee Hoffguy 01/26/18 11:40AM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 08/07/20 01:46AM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/07/20 07:44AM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 08/07/20 08:48AM
  Re: Arduino Based CDIRe: Aaron Blair Aaron Blair 08/07/20 09:33AM
  Re: Arduino Based CDIRe: Dirty30 Dillon Dirty30 Dillon 08/07/20 09:51AM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/07/20 11:04AM
  Re: Arduino Based CDIRe: Brian F Brian F 08/11/20 11:18AM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/11/20 12:40PM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 08/07/20 03:00PM
  Re: Arduino Based CDIRe: Dirty30 Dillon Dirty30 Dillon 08/11/20 12:49PM
  Re: Arduino Based CDIRe: Dickie Thompson Dickie Thompson 08/11/20 04:12PM
  Re: Arduino Based CDIRe: Aaron Blair Aaron Blair 08/12/20 10:02AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 08/12/20 11:29AM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/12/20 03:51PM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 08/12/20 04:03PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/13/20 11:26PM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 08/14/20 09:15AM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/14/20 09:18AM
  Re: Arduino Based CDIRe: Brian F Brian F 08/19/20 09:10PM
  Re: Arduino Based CDIRe: Brian F Brian F 09/21/20 10:55AM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/23/20 11:06AM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 09/23/20 02:44PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/23/20 02:47PM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 09/21/20 12:57PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/24/20 11:47PM
  Re: Arduino Based CDIRe: Brian F Brian F 09/25/20 03:51PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/25/20 09:13PM
  Re: Arduino Based CDIRe: Brian F Brian F 09/25/20 03:43AM
  Re: Arduino Based CDIRe: Brian F Brian F 09/25/20 10:02PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/28/20 02:43PM
  Re: Arduino Based CDIRe: Brian F Brian F 10/19/20 12:29PM
  Re: Arduino Based CDIRe: Mars   Mars   10/26/12 04:22PM
  Re: Arduino Based CDIRe: Mars   Mars   10/26/12 04:33PM
  Re: Arduino Based CDIRe: Mars   Mars   10/26/12 08:39PM
  Re: Arduino Based CDIRe: Cole M Cole M 11/15/14 11:26AM
