Re: Arduino Based CDI
peter heid /
Graham Motzing Wrote:
> knock happens in any engine if the timing is too
> far advanced. DI actually is able to avoid it by
> not injecting fuel until later in the combustion
> cycle.
Actually "knock" is pre-ignition, usually from a combination of heat, compression and localized hot spots. Pre-ignition happens before the ignition system gets a chance to work. Often carbon buildup can make a localized hot spot. It knocks because it is more often than not an explosion, not a controlled burn, and it pounds on the engine parts.
  Arduino Based CDITopic by: Mars   Mars   10/26/12 03:41PM
  Re: Arduino Based CDIRe: Josh G Josh G 10/26/12 03:48PM
  Re: Arduino Based CDIRe: Mars   Mars   10/26/12 03:55PM
  Re: Arduino Based CDIRe: Mars   Mars   10/26/12 04:06PM
  Re: Arduino Based CDIRe: Nele Sudar Nele Sudar 10/26/12 04:17PM
  Re: Arduino Based CDIRe: Thenggregy Cawilan Thenggregy Cawilan 08/06/20 06:45PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/07/20 07:18AM
  Re: Arduino Based CDIRe: Cooper Hennick Cooper Hennick 10/26/12 05:54PM
  Re: Arduino Based CDIRe: Jake Beckman Jake Beckman 10/26/12 06:44PM
  Re: Arduino Based CDIRe: M-Tenn Aaron M-Tenn Aaron 10/26/12 07:00PM
  Re: Arduino Based CDIRe: Nele Sudar Nele Sudar 10/26/12 07:40PM
  Re: Arduino Based CDIRe: Jason Collier Jason Collier 10/27/12 12:26AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 10/27/12 12:46PM
  Re: Arduino Based CDIRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 10/29/12 12:43AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 10/27/12 02:40PM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 10/27/12 06:24PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 10/27/12 03:26PM
  Re: Arduino Based CDIRe: Mars   Mars   10/27/12 03:35PM
  Re: Arduino Based CDIRe: NB0tt aholetechbro NB0tt aholetechbro 10/27/12 03:41PM
  Re: Arduino Based CDIRe: Mars   Mars   10/27/12 03:49PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 10/27/12 06:36PM
  Re: Arduino Based CDIRe: will warn will warn 10/27/12 08:31PM
  Re: Arduino Based CDIRe: Adam Russell Adam Russell 10/28/12 08:38AM
  Re: Arduino Based CDIRe: Adam Russell Adam Russell 10/28/12 09:10AM
  Re: Arduino Based CDIRe: Mars   Mars   10/28/12 06:56PM
  Re: Arduino Based CDIRe: Mars   Mars   10/28/12 11:50PM
  Re: Arduino Based CDIRe: 1 1 1 1 10/28/12 11:44PM
  Re: Arduino Based CDIRe: Chris B Chris B 10/29/12 10:02AM
  Re: Arduino Based CDIRe: Mars   Mars   10/29/12 10:44AM
  Re: Arduino Based CDIRe: Paul Dehmer Paul Dehmer 10/29/12 08:45PM
  Re: Arduino Based CDIRe: Time Warner Time Warner 10/31/12 07:43PM
  Re: Arduino Based CDIRe: Cooper Hennick Cooper Hennick 11/01/12 11:14AM
  Re: Arduino Based CDIRe: Mars   Mars   11/02/12 12:55AM
  Re: Arduino Based CDIRe: Sickster 6 Sickster 6 11/02/12 01:42PM
  Re: Arduino Based CDIRe: Mars   Mars   11/02/12 01:52PM
  Re: Arduino Based CDIRe: Dill . Dill . 11/03/12 01:12PM
  Re: Arduino Based CDIRe: Time Warner Time Warner 11/02/12 07:57PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/03/12 02:07PM
  Re: Arduino Based CDIRe: Dill . Dill . 11/06/12 09:46AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 11/06/12 09:50AM
  Re: Arduino Based CDIRe: Mars   Mars   11/06/12 10:29AM
  Re: Arduino Based CDIRe: Peter Fondue Peter Fondue 11/06/12 01:52PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 11/14/12 10:27AM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 11/20/12 01:57AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/20/12 09:36AM
  Re: Arduino Based CDIRe: Alejandro Schröeder Alejandro Schröeder 11/21/12 07:19PM
  Re: Arduino Based CDIRe: Mars   Mars   11/22/12 10:53AM
  Re: Arduino Based CDIRe: *.* HONDA *.* HONDA 11/22/12 08:44PM
  Re: Arduino Based CDIRe: Dill . Dill . 11/22/12 01:12PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 11/24/12 02:44AM
  Re: Arduino Based CDIRe: Mars   Mars   11/30/12 11:22PM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 12/14/12 12:18AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 12/14/12 12:35AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 12/14/12 09:05AM
  Re: Arduino Based CDIRe: Mars   Mars   12/14/12 09:54AM
  Re: Arduino Based CDIRe: The Blisster The Blisster 12/14/12 01:08PM
  Re: Arduino Based CDIRe: Mars   Mars   12/16/12 12:44AM
  Re: Arduino Based CDIRe: 1 1 1 1 12/16/12 12:50AM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 12/16/12 02:06AM
  Re: Arduino Based CDIRe: Mars   Mars   12/16/12 02:26PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 12/16/12 03:28PM
  Re: Arduino Based CDIRe: Mars   Mars   12/16/12 04:23PM
  Re: Arduino Based CDIRe: peter heid peter heid 11/16/14 07:52AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 12/16/12 04:49PM
  Re: Arduino Based CDIRe: Mars   Mars   12/16/12 05:21PM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 12/16/12 06:00PM
  Re: Arduino Based CDIRe: Ryan Mayer Ryan Mayer 12/16/12 09:11PM
  Re: Arduino Based CDIRe: SABAT! andDestroy SABAT! andDestroy 12/16/12 11:27PM
  Re: Arduino Based CDIRe: Mars   Mars   12/16/12 11:34PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 12/17/12 12:25AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 12/17/12 12:51AM
  Re: Arduino Based CDIRe: The Blisster The Blisster 12/18/12 02:15PM
  Re: Arduino Based CDIRe: Mars   Mars   12/18/12 02:22PM
  Re: Arduino Based CDIRe: Ryan Mayer Ryan Mayer 01/15/13 06:38AM
  Re: Arduino Based CDIRe: Mars   Mars   01/15/13 09:19AM
  Re: Arduino Based CDIRe: Dominic Valentino Dominic Valentino 01/15/13 11:37AM
  Re: Arduino Based CDIRe: SABAT! andDestroy SABAT! andDestroy 01/15/13 11:30AM
  Re: Arduino Based CDIRe: Mars   Mars   01/15/13 11:54AM
  Re: Arduino Based CDIRe: Ryan Mayer Ryan Mayer 01/15/13 12:25PM
  Re: Arduino Based CDIRe: Ryan Mayer Ryan Mayer 01/15/13 12:41PM
  Re: Arduino Based CDIRe: Time Warner Time Warner 01/15/13 07:05PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 01/16/13 04:15PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 01/22/13 02:44AM
  Re: Arduino Based CDIRe: Time Warner Time Warner 01/23/13 01:21PM
  Re: Arduino Based CDIRe: Mars   Mars   01/23/13 01:29PM
  Re: Arduino Based CDIRe: Ryan Mayer Ryan Mayer 01/23/13 02:09PM
  Re: Arduino Based CDIRe: Mars   Mars   01/23/13 02:57PM
  Re: Arduino Based CDIRe: Emerica   Emerica   01/23/13 08:29PM
  Re: Arduino Based CDIRe: Mars   Mars   01/23/13 08:40PM
  Re: Arduino Based CDIRe: Emerica   Emerica   01/23/13 09:04PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 01/23/13 11:16PM
  Re: Arduino Based CDIRe: Mars   Mars   01/23/13 11:28PM
  Re: Arduino Based CDIRe: M∆®†Y Køk€š M∆®†Y Køk€š 01/24/13 01:21AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/14/14 11:24AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/14/14 11:37AM
  Re: Arduino Based CDIRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/15/14 12:37PM
  Re: Arduino Based CDIRe: Thenggregy Cawilan Thenggregy Cawilan 08/13/20 12:50AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/14/14 12:42PM
  Re: Arduino Based CDIRe: Julie the Wizard Julie the Wizard 11/15/14 02:11AM
  Re: Arduino Based CDIRe: simon zarka simon zarka 11/15/14 05:10AM
  Re: Arduino Based CDIRe: Mars   Mars   11/15/14 09:34AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/15/14 04:47PM
  Re: Arduino Based CDIRe: «tyler » «tyler » 11/15/14 11:11PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/15/14 11:21PM
  Re: Arduino Based CDIRe: Mars   Mars   11/15/14 11:56PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/16/14 12:02AM
  Re: Arduino Based CDIRe: Mars   Mars   11/16/14 12:11AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/16/14 06:35AM
  Re: Arduino Based CDIRe: Thenggregy Cawilan Thenggregy Cawilan 08/13/20 12:45AM
  Re: Arduino Based CDIRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/16/14 08:28AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/16/14 02:15PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/16/14 02:19PM
  Re: Arduino Based CDIRe: Mars   Mars   11/16/14 10:24PM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/17/14 12:18AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 11:31AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 11:36AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 11:38AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/16/14 03:22PM
  Re: Arduino Based CDIRe: Cody H Cody H 11/17/14 12:34PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 12:40PM
  Re: Arduino Based CDIRe: Cody H Cody H 11/17/14 12:48PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 12:55PM
  Re: Arduino Based CDIRe: Cody H Cody H 11/17/14 01:00PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 01:09PM
  Re: Arduino Based CDIRe: Cody H Cody H 11/17/14 01:52PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/17/14 01:59PM
  Re: Arduino Based CDIRe: Cody H Cody H 11/17/14 02:15PM
  Re: Arduino Based CDIRe: Mars   Mars   11/21/14 09:10AM
  Re: Arduino Based CDIRe: peter heid peter heid 11/22/14 01:28PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/21/14 01:35PM
  Re: Arduino Based CDIRe: Mars   Mars   11/21/14 02:14PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/21/14 03:51PM
  Re: Arduino Based CDIRe: Mars   Mars   11/21/14 04:16PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/21/14 06:18PM
  Re: Arduino Based CDIRe: «tyler » «tyler » 11/24/14 09:07AM
  Re: Arduino Based CDIRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/23/14 06:47AM
  Re: Arduino Based CDIRe: Deadped Ryan Deadped Ryan 11/24/14 10:04AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 11/25/14 11:28AM
  Re: Arduino Based CDIRe: Mike Boyd Mike Boyd 03/04/16 04:17PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 03/11/16 12:52PM
  Re: Arduino Based CDIRe: Andres Pioli Andres Pioli 01/25/18 07:48PM
  Re: Arduino Based CDIRe: Mikey Antonakakis Mikey Antonakakis 01/25/18 10:41PM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 01/26/18 10:42AM
  Re: Arduino Based CDIRe: Mikey Antonakakis Mikey Antonakakis 01/26/18 06:05PM
  Re: Arduino Based CDIRe: Lee Hoffguy Lee Hoffguy 01/26/18 11:40AM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 08/07/20 01:46AM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/07/20 07:44AM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 08/07/20 08:48AM
  Re: Arduino Based CDIRe: Aaron Blair Aaron Blair 08/07/20 09:33AM
  Re: Arduino Based CDIRe: Dirty30 Dillon Dirty30 Dillon 08/07/20 09:51AM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/07/20 11:04AM
  Re: Arduino Based CDIRe: Brian F Brian F 08/11/20 11:18AM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/11/20 12:40PM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 08/07/20 03:00PM
  Re: Arduino Based CDIRe: Dirty30 Dillon Dirty30 Dillon 08/11/20 12:49PM
  Re: Arduino Based CDIRe: Dickie Thompson Dickie Thompson 08/11/20 04:12PM
  Re: Arduino Based CDIRe: Aaron Blair Aaron Blair 08/12/20 10:02AM
  Re: Arduino Based CDIRe: Graham Motzing Graham Motzing 08/12/20 11:29AM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/12/20 03:51PM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 08/12/20 04:03PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/13/20 11:26PM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 08/14/20 09:15AM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 08/14/20 09:18AM
  Re: Arduino Based CDIRe: Brian F Brian F 08/19/20 09:10PM
  Re: Arduino Based CDIRe: Brian F Brian F 09/21/20 10:55AM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/23/20 11:06AM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 09/23/20 02:44PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/23/20 02:47PM
  Re: Arduino Based CDIRe: Jay Rivett Jay Rivett 09/21/20 12:57PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/24/20 11:47PM
  Re: Arduino Based CDIRe: Brian F Brian F 09/25/20 03:51PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/25/20 09:13PM
  Re: Arduino Based CDIRe: Brian F Brian F 09/25/20 03:43AM
  Re: Arduino Based CDIRe: Brian F Brian F 09/25/20 10:02PM
  Re: Arduino Based CDIRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/28/20 02:43PM
  Re: Arduino Based CDIRe: Brian F Brian F 10/19/20 12:29PM
  Re: Arduino Based CDIRe: Mars   Mars   10/26/12 04:22PM
  Re: Arduino Based CDIRe: Mars   Mars   10/26/12 04:33PM
  Re: Arduino Based CDIRe: Mars   Mars   10/26/12 08:39PM
  Re: Arduino Based CDIRe: Cole M Cole M 11/15/14 11:26AM
