Re: Stock Peugeot Variator Mod: How-To
Jesse Simonsen /
> jumpsuit steve Wrote:
> > Zach Riddle Wrote:
> > I dont want a clutch pulley and i dont want stock clutch.
> > Ideally I would like to find a cost effetive and reliable clutch set
> up
> >really i just want to figure out somesort of clutch set up that doesn't
> cost 300 but >can slip and grab hard for cheap
> > for peugeots
> three thoughts! :
> A:) has anyone tried the XP50 clutch on a single variated machine yet?
> B:) you could get a thin, steel clutch plate made, get two fiber plates,
> get those ground down, and bond em to the center steel plate.
> C:) you could try running 6 (or some combination of) silicon nitride
> balls which would balance out the applied pressure, without the weight
> penalty.
Funny you mention the homemade discs. I spoke to tribco about this awhile back and they will line a metal disc with their Kevlar( I believe it was) friction material. You will need to machine out a disc plate.
With the right thickness steel plate they have material thin enough to line both sides and get it to 4mm. Once they have the steel plate from you they can machine out more and make as many disc set ups as you want.
I abandoned the idea though.
My problem was I was trying to run without the starter shoes and use a rope start.
I kept destroying discs and locking rings.
I had an er3 set up that was mounted at 4 points to the locking ring instead of two and still kept bending the locking rings and breaking discs.
I was using 4 ceramic balls and two star spring and had the clutch engaging at 6400 rpms. Clutch pulley performance but almost every ride something in there was breaking or wearing out. Even the star spring were getting flattened and would lose their springiness.
I tested out engagement point weights using Delrin balls and was able to get 10000 rpm engagement but the balls would melt after a few launches so there is a lot of heat inside there.
I now run an er86 clutch pulley and wish I would've had a clutch pulley from the start.
  Stock Peugeot Variator Mod: How-ToTopic by: Jake P Jake P 09/23/12 02:27AM
  Re: Stock Peugeot Variator Mod: How-ToRe: cheetahchrome . cheetahchrome . 09/23/12 01:09PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Jake P Jake P 09/23/12 01:48PM
  Re: Stock Peugeot Variator Mod: How-ToRe: johno roberts johno roberts 09/23/12 02:53PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Charlie BUZZARD Charlie BUZZARD 09/23/12 03:15PM
  Re: Stock Peugeot Variator Mod: How-ToRe: johno roberts johno roberts 09/23/12 03:30PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Jake P Jake P 09/23/12 04:16PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Charlie BUZZARD Charlie BUZZARD 09/23/12 04:58PM
  Re: Stock Peugeot Variator Mod: How-ToRe: johno roberts johno roberts 09/23/12 05:47PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Mel Dyer Mel Dyer 09/24/12 02:39AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Fish tits Krauthamer Fish tits Krauthamer 09/24/12 02:54AM
  Re: Stock Peugeot Variator Mod: How-ToRe: johno roberts johno roberts 09/24/12 03:48PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Charlie BUZZARD Charlie BUZZARD 09/30/12 07:25PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Mo Peds Mo Peds 09/30/12 07:34PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Drew Bell Drew Bell 09/30/12 08:49PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Deadped Ryan Deadped Ryan 09/30/12 09:12PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Drew Bell Drew Bell 10/01/12 09:57AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Deadped Ryan Deadped Ryan 10/01/12 10:22AM
  Re: Stock Peugeot Variator Mod: How-ToRe: johno roberts johno roberts 10/02/12 03:10PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Charlie BUZZARD Charlie BUZZARD 10/02/12 03:50PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Jake P Jake P 10/29/13 05:40PM
  Re: Stock Peugeot Variator Mod: How-ToRe: M-Tenn Aaron M-Tenn Aaron 10/29/13 09:27PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Dirty30 Dillon Dirty30 Dillon 10/29/13 06:12PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Toledo Riot Toledo Riot 08/13/19 12:15AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 12:13PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Jake P Jake P 08/23/19 12:16PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/23/19 01:13PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Jake P Jake P 08/23/19 01:21PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Toledo Riot Toledo Riot 08/23/19 04:46PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Toledo Riot Toledo Riot 08/23/19 04:52PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Graham Motzing Graham Motzing 08/23/19 05:12PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 01:03PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Graham Motzing Graham Motzing 08/23/19 03:18PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 01:44PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 04:02PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/23/19 08:08PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 09:07PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 09:08PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/23/19 09:14PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 09:52PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/23/19 09:57PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Travis King Travis King 08/24/19 01:17AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/24/19 01:26AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/24/19 10:23AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/24/19 01:32PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/26/19 07:14PM
  Re: Stock Peugeot Variator Mod: How-ToRe: jumpsuit steve jumpsuit steve 08/28/19 08:33AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/28/19 09:00AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Jesse Simonsen Jesse Simonsen 08/28/19 10:50PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Blake Totally a real doctor Blake Totally a real doctor 08/25/19 11:40AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Toledo Riot Toledo Riot 08/26/19 04:05PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Graham Motzing Graham Motzing 08/26/19 06:20PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/27/19 01:50AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Travis King Travis King 08/28/19 06:05PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/28/19 11:10PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Travis King Travis King 08/28/19 06:11PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Travis King Travis King 08/28/19 06:33PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Travis King Travis King 08/28/19 08:16PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Toledo Riot Toledo Riot 08/29/19 01:05PM
