you can get the clutch er3 or the clutchless, which is the same as the moby but with a different hub. the clutched er3 reuses the stock clutch.
yeah the vario is like the only reason i don't fux with moby, you either do a stock 2 ball or you jump in the deep end with a clutch pulley, there is no in between.
