Stock Peugeot Variator Mod: How-To
Jake P /
Original post was by johno roberts.
here.
Now is a great time to drop down to 2 or 3 clutch balls and 2 star springs too!
You will need:
bench vice
Hammer/flat punch
cressent wrench OR 32mm socket/ratchet
phillips screw driver
dremel/ saw
Loctite
4x 1/4" nuts (optional)
1. remove your variator from the bike. if you dont know how this is done stop now and learn how your bike comes apart
2. To disasemble the Variator put vario in the vice, flatten the locking washer, Remove the inner sleeves and plastic bushings, then remove nut which hold the vario togather. Disassemble the Variator.
3. now using the phillips driver remove the weights
4. use a scale to modify or change the weights. You can use stock, trimmed, SAE 1/4" nuts, ER3, or no weights. This all depends on your motor and spring combination.
5. Install the weights of your choice using BLUE loctite. I run 1/4" nuts for my kitted 50cc 103.
6. OPTIONAL: I also remove the rubber dampeners under the variator arms. Less resistance is always better in my book.
Just so you know this vario will NOT start to shift till about 25-35mph so make sure you can spin the rpm to variate it. (Aftermarket 50cc or 70cc kit)
"Other cheap mod is to buy some variotop weights, they bolt right in at the same 2 mounting holes that are on the stock arms.
-naz"
  Stock Peugeot Variator Mod: How-ToTopic by: Jake P Jake P 09/23/12 02:27AM
  Re: Stock Peugeot Variator Mod: How-ToRe: cheetahchrome . cheetahchrome . 09/23/12 01:09PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Jake P Jake P 09/23/12 01:48PM
  Re: Stock Peugeot Variator Mod: How-ToRe: johno roberts johno roberts 09/23/12 02:53PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Charlie BUZZARD Charlie BUZZARD 09/23/12 03:15PM
  Re: Stock Peugeot Variator Mod: How-ToRe: johno roberts johno roberts 09/23/12 03:30PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Jake P Jake P 09/23/12 04:16PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Charlie BUZZARD Charlie BUZZARD 09/23/12 04:58PM
  Re: Stock Peugeot Variator Mod: How-ToRe: johno roberts johno roberts 09/23/12 05:47PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Mel Dyer Mel Dyer 09/24/12 02:39AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Fish tits Krauthamer Fish tits Krauthamer 09/24/12 02:54AM
  Re: Stock Peugeot Variator Mod: How-ToRe: johno roberts johno roberts 09/24/12 03:48PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Charlie BUZZARD Charlie BUZZARD 09/30/12 07:25PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Mo Peds Mo Peds 09/30/12 07:34PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Drew Bell Drew Bell 09/30/12 08:49PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Deadped Ryan Deadped Ryan 09/30/12 09:12PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Drew Bell Drew Bell 10/01/12 09:57AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Deadped Ryan Deadped Ryan 10/01/12 10:22AM
  Re: Stock Peugeot Variator Mod: How-ToRe: johno roberts johno roberts 10/02/12 03:10PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Charlie BUZZARD Charlie BUZZARD 10/02/12 03:50PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Jake P Jake P 10/29/13 05:40PM
  Re: Stock Peugeot Variator Mod: How-ToRe: M-Tenn Aaron M-Tenn Aaron 10/29/13 09:27PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Dirty30 Dillon Dirty30 Dillon 10/29/13 06:12PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Toledo Riot Toledo Riot 08/13/19 12:15AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 12:13PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Jake P Jake P 08/23/19 12:16PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/23/19 01:13PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Jake P Jake P 08/23/19 01:21PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Toledo Riot Toledo Riot 08/23/19 04:46PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Toledo Riot Toledo Riot 08/23/19 04:52PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Graham Motzing Graham Motzing 08/23/19 05:12PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 01:03PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Graham Motzing Graham Motzing 08/23/19 03:18PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 01:44PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 04:02PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/23/19 08:08PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 09:07PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 09:08PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/23/19 09:14PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/23/19 09:52PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/23/19 09:57PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Travis King Travis King 08/24/19 01:17AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/24/19 01:26AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/24/19 10:23AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/24/19 01:32PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/26/19 07:14PM
  Re: Stock Peugeot Variator Mod: How-ToRe: jumpsuit steve jumpsuit steve 08/28/19 08:33AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/28/19 09:00AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Jesse Simonsen Jesse Simonsen 08/28/19 10:50PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Blake MD No PM Plz Blake MD No PM Plz 08/25/19 11:40AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Toledo Riot Toledo Riot 08/26/19 04:05PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Graham Motzing Graham Motzing 08/26/19 06:20PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Daniel '' Daniel '' 08/27/19 01:50AM
  Re: Stock Peugeot Variator Mod: How-ToRe: Travis King Travis King 08/28/19 06:05PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Zach Riddle Zach Riddle 08/28/19 11:10PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Travis King Travis King 08/28/19 06:11PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Travis King Travis King 08/28/19 06:33PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Travis King Travis King 08/28/19 08:16PM
  Re: Stock Peugeot Variator Mod: How-ToRe: Toledo Riot Toledo Riot 08/29/19 01:05PM
