moby 50v 15/15 sha
charles benda /
first what is more helpfull calling my moped a moby 50v, or moby mobolett.
so im looking into getting the 15/15 sha. reading on wiki it talks abaut useing a 14mm intake. i would think you should use a 15mm intake and should it be a bendy or a shorty.
also will the change lead to more breack downs
Re: moby 50v 15/15 sha
charles benda /
were else can you get intakes 1977 moped seams to be out of stock
charles benda /
dose the lever chock fit like the cable chock. it sound like it will, but in the pic it looks taller. and is it worth the 4$ extra. is there any towning proplems with the switch
I personally like the lever choke over cable choke, one less annoying cable to deal with.
kim jensen /
Get the 15 shorty, you will need to grind a little off the cylinder intake on the left side to facilitate proper fuel flow. But you can't do much as the cylinder mounting stud bolt is right behind it. Just widen and shape slightly. The 15 bendy is much wider than the opening on the cyl.
You really need some kind of spell checker on your computer.
use the cable choke, so if your kit gets hot, you can pull it for an extra blast of cooling, lubricating fuel while riding
But the lever choke means your not using side covers, right? (edited)
charles benda /
sorry i acualy have not thought of that
