need help timing a puch e50
So I just fully rebuilt my Puch Maxi e50 and installed a new crank with it too. Little did I know - since I'm a newbi to the moped world - I also need to do the timing on it. I was hoping there might be someone in SLC, UT that might be able to help me or if somebody could point me in the right direction I'd be super stoked.
Re: need help timing a puch e50
-First you should download the service manual from here , it has the specs and a technical description of how to do it.
-Check the wiki it has a ton of how to info and here is the " Ignition timing for points " article
-check out this video for a visual description but use real feeler gauges not cardboard
(edited)
