what is optimum temp range for an E50
I have this lazer temp gauge i use to tune my nitro rc cars. I have been using it to read the temp of the cylinder after a good bashing on the motor. I have no more four stroking after i finally put a 50:1 mixture in it. My max. temp reading has been under 200 degrees. CLoser to 145-150. I use Koltz R50 Synthetic oil. Could i go a tad bit leaner? I am on a stock piston and rings and want it to last this season but, plan to kit it over the winter. What is the hottest i want to be after blasting for an hour or more. I tend to hold WOT for a good minute. I guess i just don't know how long you can hold them wide out without worring also. One mile? five miles WOT? these readings have been only after about a half hour of blasting around the hood.
Should i be taking readings after longer rides? Questions...questions..
thanks for any posative reply.
Re: what is optimum temp range for an E50
I think you'd be better off with one that screws in under the spark plug
Well of course i would Mike. But for now this is what i have and it cost more than the one that you "put on the plug"( which i have read many bad reviews about.) I tune $250 Nitro Motors with the one i have and am confident in it. My Nitro motors, which are 1/32 the size of an E50, run in the 200F-220F range. Lets say i HAD one that went on the plug... what should the max reading be, before i need to worry. (edited)
The problem is its 2 completely different and unrelated numbers. Look up the thread kstar perfectly tuned. That guy was blasting all over the place and reading sub 200s. I have the trailtech and blast wide open for 20 minutes and will read 365. 375+ seems to be the caution range and over 400 gets you into the danger zone. (edited)
Overpriced Parts /
Without a trail tech head temp gauge your sooo far off its not funny.
why even bother to post
Salsa Salsa /
your below 200 and asking if you can go leaner?
do some reading, some research, some learning, you can go way leaner rim job!
COME MOAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
very clever..i see what you did there...
Salsa Salsa /
Yeah. I made a joke about eating ass holes. Yummy.
my kstar e50 hits 450-460 regularly with no issues. my dr kit honda hit 500 yesterday and I puled over and shut it down to cool it off before it melted
450 on a kstar? what the fuck. dr kit hobbit 500???? I hope you're joking.
Salsa Salsa /
When ever I hit 500 my temp gauge says reads a flashing MAX
Overpriced Parts /
450-500 degrees is just too high. re tune/time for lower temps
A local kid seized his kstar at 458 degrees.
I got no bike now that goes over 390 degrees.
I can't wait until they come out with a 74cc watercooled puch kit
